Question about Whirlpool Dryers
Maintenance lights won't go away
Hello. thank you in advance for your help. i have a Bauknecht TK Care 6B dryer. i live in germany and i know bauknecht is manufactured as whirlpool in the states. after 6 months of use the dryer stopped and 3 red lights started blinking. each light indicated empty water container, clean heat unit, and clean dirt filter. not knowing much german, i just realized i didn't clean the heat unit on the bottom of the dryer on a monthly basis. i cleaned everything according to the maintenance instruction but the red lights won't go away and the dryer won't start. please help! elaine
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Posted on Apr 24, 2017
dididsaythat
  • 291 Answers
SOURCE: Not heating up
I would check the thermo fuse in the back of dryer.. its on the burner towards the top.. use omh meter and check if its good. If you dont have a meter, if very careful and just hook wires togeter and tape so nothing touches and will not short out by touching anything, bypass switch JUST to see if switch is bad! Replace it if bad
Posted on Sep 05, 2007
heatman101
  • 43501 Answers
SOURCE: my whirlpool awz7303 is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: Teka dryer model TLK 6100,
Even though yours is self draining you is still gonna have to yank out the condenser and wash it out.
Never heard of a teks but I do have acceess to a type of dryer like yours. That will give you an idea what to do:
ASKO Service manual
Posted on Oct 23, 2010
quiggers
SOURCE: I have a Candy Grand 8g vented tumble dryer. No
Its a wierd coincedence I have the exact same problem this morning,and my identical unit is 6 months old.Misery loves company,I will read the on line fault finder manual for this unit and hopefully find an answer
Regards Quiggers in Ireland
Posted on Nov 28, 2010
jumptrout51
  • 3361 Answers
SOURCE: Hello I have a Beko
Clean the exhaust line connected to the rear of the dryer.
Run a load of laundry with the rear duct removed completely and see if the light comes on.
Posted on Mar 10, 2011
1988 Buick Regal 2.8 - park/turn relay
eBay, or try autozone, advance auto in the states
Aug 04, 2013 | Cars & Trucks
2006 Tk barina - won't start!!! :(
these had issues of not starting when cold and missfiring only when cold
this was due to valves sticking due to carbon build up
head of and get valve guides modified as per holden info (scrapper counter sunk guides)
May 28, 2013 | Holden Barina Cars & Trucks
Washer imbalanced
hello,
if you put to little material in your waschingmachine it cannot ballance ,
the content will just fall around inside the machine , witch couses the "banging".
fill up the machine to minimal half full..
i do hope i helped you
hugo lindhout from germany
hugo.lindhout@gmx.de
Jan 31, 2013 | Kenmore Vehicle Parts & Accessories
BAUKNECHT WA 709 SC
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
IFit treadmill won't turn on. There is power to the plug.
Dear Sir:
Thank you by you request, I hope everything is fine.
I will try to help you.
Do this :
    • 1
Lookat the circuit to be measured, in this case I chose to check an outlet. In thiscase I need to check if an outlet is live.
    • 2
Keep fingers behind the fingerprotectors Thevoltage in a house circuit will range from 120 Volts in the wall outlets, to220 Volts at the range and dryer outlet. Both of which can kill instantly. Thisis where extreme care and safety must be observed. Inspect leads and probes fordamage and cracks. If any damage or cracks is found DO NOT USE, THROW AWAY!!!Keep fingers behind the finger guard as seen in the picture.
    • 3
200 Volts AC scale Choosea range which exceeds the voltage you expect to measure. You will need tochoose the AC scale.
    • 4
Measuring wall outlet to test forvoltage.
Thank you in advance,sincerely. Blessing.
If you need further assistance, please reach me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Oct 02, 2011 | Exercise & Fitness
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
Hello, I am looking for staples for my Black & Decker Powershot 5700, I am now living in Germany, can you help me to find staples in 12mm and 14mm lengths? Thank you Silke M. Russell
Hi, Please visit the eBay URL below..Heavy-Duty Staples available there and most ships to Germany too..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://home.shop.ebay.com/Nail-Staple-Guns-/20779/i.html?_kw=staples&_clu=2&_fcid=204&_localstpos=&_sc=1&_sop=15&_stpos=&gbr=1
Jun 26, 2011 | Black & Decker 5700 Powershot Forward...
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
