Question about Marantz CD-67 SE CD Player
Marantz cd-67se problem:When clicking the button to open the disc tray does not open sometimes
4 Suggested Answers
  • 9 Answers
SOURCE: I have a marantz cd re-corder but I insert a cd rw disc or cd r
check the manual for what types of discs you can use.
Posted on Jan 15, 2010
  • 99 Answers
SOURCE: CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Posted on Sep 12, 2010
  • 99 Answers
SOURCE: Marantz CDR631 is dead
open it up and take the mechanism out, then you should see a servo PCB screwed to the underside of the mechanism.
unscrew this and where the connecting wires plug in from the main PCB, you should see 2 or 3 fuses which look a bit like capacitors and should be red in colour marked MPXXX eg. MP100?
replace these if you can find spares, if not bridge them with a bit of thin wire soldered in place and then it should switch on once reassembled.
the clicking sound you mention will be the main power supply capacitors running and this is normal.
Posted on Sep 21, 2010
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
My marantz cd 7300 reads no disc probably needs a new laser, where do i get one, thoes sold on ebay look different, many thanks, Peter.
This sounds crazy but it works for some reasons. Marantz CDR500 would not read and initialise some blank discs but no problem with reading finalised ones and erratic would and would-not work. Tried cleaning lens and even blowing ar through it. Before I wasted money in air I thought why not try hairdryer into open tray and lens area and just for measure across blank CD. I know this sounds weird but it worked every time and machine will read any make of disc like this. I do not have any scientific explanation only the fact that it works!!!
Nov 23, 2013 | Marantz Audio Players & Recorders
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
105 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
