Question about LG WM-2077C Front Load Washer
LG Tromm washer WM2077CW reading code LE
Washer is not working and giving me a code ''LE'' in the display. what does this mean?? Our LG machine is displaying LE as well and doesn't work what does this mean? Thanks Eric
  • 3 more comments
  • Anonymous Mar 14, 2014
    What does a flashing "Ue" mean?
    lg tromm washer What does flashing "Ue" mean?
  • Anonymous Mar 18, 2014
    its starts its cycle and within 5 min of cycle i get a EE code ...doesnt happen all the time hat does this mean
  • Mayomi Ayo
    Mayomi Ayo Mar 14, 2016
    Ue.....has something to do with drainage or clean the water pump cup
  • Mayomi Ayo
    LE means level error nd it has something to do with balance or the door
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator or rotor may be defective.
Posted on Mar 16, 2016
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
MY LG TROMM WM2077CW WASHER DRUM WILL SPIN FOR A BIT THEN IT STARTS STUTTING AND WON'T SPIN. THANKS SCOTT
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
May 03, 2011 | LG WM2016C
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer won't fill. code LE
Try unplugging and replugging. Apparently it does a reset of something. It worked for me. I would make sure you don't have to much laundry in the machine too.
Dec 10, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what the tell you is the meaning of a code"le" on your specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Jul 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2077C Front Load Washer Logo
3,427 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
