Question about LG RUMOR Cellular Phone
Bluetooth pairing i'm trying to pair my bluetooth with my friend's so that i may receive music and other things. when the devices finally find each other my friend is able to type in her passcode but i'm not sure what my passcode is. what do i do?
    Problem Solver:
  • 7 Answers
Ur divice has a special type of bluetooth facility .Because of this u will not connect to some other devices.
Posted on May 31, 2009
How to pair bluetooth
One device sends the Bluetooth signal. For example, your smartphone can send a Bluetooth signal to play music from the phone on a portable speaker, or you might send it to a wireless earphone to make hands-free phone calls.
The second device receives the Bluetooth signal and plays the sound or picture.
To pair them, first set the receiving device (example: Bluetooth speaker) in "pairing mode". This is usually done by pressing a certain button on the receiving device for 3 or 4 seconds. Next, on your sending device (example: your phone) open the Bluetooth settings and select to search for Bluetooth devices. Your receiving device should appear in the list of available Bluetooth devices. Tap to connect to the receiving device. This may take up to 15 seconds. You should see a message on one or both devices saying "Connected".
Jan 01, 2016 | Audio Players & Recorders
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
Nov 07, 2015 | ASUS 8GB ME170C MeMO Pad 7" Wi-Fi Tablet...
Bluetooth will not activate, tx-nr636 setting says its on but no light and device will not connect
To connect a Bluetooth-enabled device (phone, tablet, iPad, iPod, computer), follow the steps below:
1. Press and hold the button to put the receiver in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the receiver.
2. Turn on Bluetooth on the device you want to connect with the receiver and tap on Scan. The device will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the receiver's name, tap on the name to pair with the device. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the receiver will turn to a steady blue and you will see 'Connect' on the device. The two are now paired.Tap on Connect and then you will see Connected on the device. Your device and the receiver are now connected.
The steps above should be detailed in the set up guide that came with the receiver. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the device to the receiver, a "get to know you" process. After that, you just need to connect the two.
I am assuming that you have already hooked up speakers to the receiver. Start playing music from your device and enjoy listening to it through the receiver's speakers !
Dec 28, 2014 | Onkyo TX-NR636 Receiver 7.2 Channels, 95...
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How to activate the bluetooth on my nuvi1300
To activate your Bluetooth, touch Tool>>Settings>Bluetooth.
For Bluetooth connection, touch the button to pair a Bluetooth device with wireless technology or any device you want to connect with. To disconnect from other Bluetooth device, touch the drop from the screen. To wipe off the Bluetooth device you paired to your nuvi, Touch remove from the nuvi paired list, and it will delete it from the nuvis memory.
Dec 25, 2010 | Garmin nuvi 1300 Car GPS Receiver
Iphone won't work with bluetooth in mazda 3 2010 My iphone shuts off whenI try to use the bluetooth system in my mazda 3
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
Jun 12, 2009 | Apple iPhone 3G
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
LG RUMOR Cellular Phone Logo
128 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
