Question about Timex Watches
Beep and chime will not work
My battery died on my timex ironman watch. i replaced it today (cr2016). now when i set everything, the beep and chime no longer will work. i turn them off, i turn them on, and nothing for the hourly beep nor the alarm. when the battery died, there was a long continuous beep from my watch. could the "speaker" have gotten fried??? Same problem. My battery died months ago. I just replaced it today, but the chime won't work. Ideas? Thanks.
  • 4 Answers
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
  • jj Sep 13, 2010
    I had the same problem and took off the back plate. I had installed it 180 degrees off. When I reinstalled so the springs lined up with the contact point on the back the watch started beeping again.
My watch also didn't chime after changing the battery. After reading the answer, I open up the watch again and changed the orientation of the back-plate and the beeps and chime worked again.
Posted on Dec 04, 2014
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do i turn off the hourly beep on my timex ironman t5k160?
press and hold the upper left button which is set, the seconds blinks then press the mode button/the lower left button until it reaches the chime turn it off pressing the middle button once. if your done press the "set" or upper left button. i hope i had been helped you.
Aug 10, 2011 | Timex IRONMAN Triathlon 50-Lap Mid T5K160...
Evening: I have had my data link for about 3 years. The battery went dead so I went to a watch repair place to have the battery replaced. The watch works great, BUT it doer not beep. All the beeps are...
Same thing happened to me, took watch to watch shop, they changed the battery and the chimes stopped working. Simple fix, the faceplate was put back on wrong. Unscrew the face plate and turn it upside down (or right side up depending on your POV) the circle on the inside of the faceplate will line up with the springs inside the watch and the chimes will start working again. If you have a pair of eyeglasses screwdrivers, like I did, you can do this yourself.
Nov 25, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
How do i set the hourly chime on the timex ironman flix watch?
Press Mode till you are in Alarm setting
Press and hold split/start button till you hear the double beep. You should also see a small clock icon above the last digit of the seconds... you are all set. Repeat to deactivate hourly chime.
Nov 12, 2009 | Timex Ironman Flix 100 Lap Unisex Watch
I had the battery replaced by a watch repair person. The watch is working but the beeps are gone. I don't have the manual and I can't figure out how to reset the beeps. Thanks.
They should have reset (AC) the watch when the battery was replaced. If not you should have them do it for you. You should also be sure the watch is resealed and pressure tested to maintain water resistance.
For manuals you can download from the Timex website. The manual will tell you if/how the chimes turn on and off.
http://assets.timex.com/manuals/?timexBrand=core
Sep 18, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Replaced battery- alarm won't chime anymore even though "ON"
I removed the battery myself, and underneath are 2 metal prongs. One was bent down and not touching the battery. I pulled both of them up so they would touch the battery, and now it works fine.
Aug 24, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
I want to know how to turn on the hourly chime on timex ironman 30 lap watch
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Dec 14, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Watches Logo
918 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
