Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Map sensor Iwas in search of technical data on the process of trouble shooting an electrical problem on my 2002 fxst specifically the map sensor the bike will start and run fine for afew blocks then die like it runs out of gas we have don your typical geuss work replaced the petcock l checked the internals of the carb verified gas flow but it still dies out like a fuel starvation problem
  • Anonymous Feb 08, 2009
    i have a 02 fxsti that acts the same way at times. it will run fine for days then it cuts out for 6 or 8 times then runs again. i checked tank and put new fuel line on. what else
Gas cap
Posted on Feb 28, 2010
I have 2001 Fat Boy 90000 miles My check engin light comes on when i get up to 75 80 mph Be for I take it in to H.D. shop is their any thing I cac check?
Posted on Oct 13, 2008
    Brigadier General:
  • 6,966 Answers
Have not worked on an HD but my thoughts and additional guesses would be:
1. fuel contamination (water at bottom of tank);
2. primary pump (in my case it was inside the fuel tank & might not be present in your bike);
3. fuel lines & clamps to & from primary pump or to the carbs;
4. in line filters;
5. vacuum controlled fuel valve (oppose to the usual manual petcock)
6. if it were the MAP sensor, bike wouldn't even run a block away + idling would be rough;
7. by chance are you using a Power Commander?
Also your post "bike will start and run fine for a few blocks then die" indicates that indeed fuel got into the carbs before but not when running meaning the bike used what was inside the bowl and was not replenished.  Alternately, the fuel flow to the carbs might not be sufficient and there is a leak or a blockage somewhere.
As said might not work for your bike but has come across some of the above on numerous occasions.
Good luck and Kind regards.
Ride Safe.
Posted on Oct 23, 2007
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
2002 aztek stalls after driving for a while
Does it start back up right away ? If not check for spark at a spark plug . Do you know how to do that ? Hold plug wire end near ground and have a helper try to start the vehicle . If there is spark , check fuel pressure . Videos on youtube showing how to do these basic test's . After you find out what is missing , then it gets a little harder . Electrical testing the system that's the problem .All kind of good videos on youtube for trouble shooting ignition , fuel systems . Video's on basic automotive electrical testing . You also need to be aware of the complexity of the engine control systems . PCM/ECM - engine computers .Also serial data communication networks , in the case of your pontiac GM used Class 2 data bus for module communication network . A engine sensor starting to short out can cause problems like you are having also . Shorting out the 5 volt ref. voltage the engine computer sends out to the sensors on the engine. Like the TPS - throttle position sensor , MAP - manifold absolut pressure sensor , crankshaft position sensor , camshaft position sensor . There are a couple others , doesn't matter . Test for the 5 volts at the easiest place TPS . Less then 5 volts one of the other sensors is shorted . More then 5 volts shorted to vehicle battery power . Trouble shooting the modern computer controlled car is no piece of cake .
Dec 26, 2016 | 2002 Pontiac Aztek
Code u1000 code p0105 u1152
Codes U1000 & U1152 are related to the digital data bus communications, U1152 is specific for the HVAC control unit data bus. troubleshooting this will require a Tech II scan tool.
P0105 is related to the MAP sensor circuit.
Apr 27, 2014 | 2002 GMC Envoy
Starts then shuts off
You should do fuel pressure testing , check for a good spark . Have a scan tool hooked up ,check for codes , look at engine sensor data parameters etc.... Look on youtube for diagnostic videos . engine dies etc... An check out basic electrical trouble shooting videos ,how to test fuel systems an ignition system testing . Find which system is causing trouble , then go to www.bbbind.com for free wiring diagrams . Then trouble shoot the problem .
Mar 30, 2014 | 1999 Dodge Durango
2002 fxst stalling
Hi Jimmy, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Aug 17, 2012 | 2002 Harley Davidson FXST Softail Standard
Need location of 2002 intrepid map sensor and how to change it
The MAP sensor mounts to the driver side of the intake manifold plenum.0996b43f802022b9.jpg
Removal & Installation
  1. Remove the negative battery cable.
  2. Disconnect the electrical connector from the MAP sensor.
  3. Remove bolts from sensor.
  4. Remove sensor.
To install:
  1. Bolt sensor to intake.
  2. Attach electrical connector to sensor.
  3. Install the negative battery cable.
Jul 23, 2011 | 2002 Dodge Intrepid
I have 2 trouble codes on my 2002 dodge ram 1500 codes p4032 main catalyst below threshold bank2 aqnd p0420 catalyst system efficiency below threshold. how do i trouble shoot the cat or sensor fault
9 times out of then this points to bad cat and the cat will need be changed.
Other things that can cause this code are an exhaust leak before the front 02 sensor or the car in need a of a tuneup badly. Generally if this problem is sensor related you would have other codes also.
If you want to know of the cat is bad the computer stores data and when you have a data scanner that can access MODE 6 the data can indicate whether your cat is the issue or not. Its a bummer you have to have this diagnosed by a professioal to get this data since the scanners do not get loaned out.
I have heard of alot of cats that were replaced for no reason because of other reasons so be cautious on how to address this because your not going to be able diagnose this without a data scanner and all the specifications for the sensors.
Mar 30, 2010 | 1998 Dodge Ram 1500 4WD
2003 Trailblazer Ltz 6 Cylinder Service engine light on. computer said Map sensor and Cooling temp sensor I replaced Map Sensor and Cooling temp sensor will be done tomorrow Car lost all Power going up...
computer said Map sensor and Cooling temp sensor I replaced Map Sensor and Cooling temp sensor will be done tomorrow . No DTC - diagnostic trouble code say's to replace a part , with each factory DTC a diagnostic flow chart or trouble shooting chart is supplied . Checking the electrical circuit , computer etc... before any parts are replaced . From your post i would say your best bet would be to take your vehicle to a qualified repair shop .
Mar 23, 2017 | 2003 Chevrolet TrailBlazer
Code po741 on a cadillac deville dhs 2001
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
Your car actually has a viscous converter clutch inside the torque converter instead of a (mechanical) torque converter clutch to lock up the torque converter for fuel economy improvement. You will see it referred to as the VCC and/or TCC.....
The TCC/VCC has a variety of components in the system including an electrical circuit supplying the transmission, the apply solenoid inside the trans, the torque converter itself, the PCM that controls the apply, etc. It is impossible to diagnose from afar. Unlikely that it is a "sensor" inside the trans as the PCM controls the VCC apply and uses engine and trans data that it receives from a variety of sources. If a "sensor" had failed the trouble code for that sensor would be setting......
Something as simple as the brake switch can cause the VCC to not apply correctly. There is a safety switch on the brake pedal that activates the brake lights and disconnects the VCC circuit. If it is misadjusted then the trans cannot apply the VCC. Lots of other trouble shooting items on the VCC system. If you don't have a service manual and cannot trouble shoot the system, I would recommend a Cadillac dealer as they have the trouble shooting information for the specific VCC that the Cadillac 4T80E trans has that a trans shop is simply not familiar with. No sense working on the trans until you actually know what is wrong.
Jan 13, 2010 | 2001 Cadillac DeVille
How to change a throttle position sensor on a 94 ford f150 5.0 4x4
How to Replace a Throttle Position Sensor
(DIY & Save up to $135.75 ) - Time: 2.1 hours
Parts:
1. Throttle Position Sensor - $ 55.44
Tools:
1. Scan Tool
2. Screwdriver
3. Multimeter
Procedure:
1. Locate the OBD data link connector (DLC). Refer to your owner’s manual for the specific location.
  • Tip: The OBD-I data link connector is usually located in the engine compartment near the battery or the fuse box. The OBD-II connector (post 1995 cars) is usually located beneath the instument panel next to the steering column.
2. Turn your key to the“ON” position. Do not start the engine.
3. Plug your scan tool into the OBD data link connector. Turn on the scan tool and select the appropriate steps to read the diagnostic trouble code (DTC).
Scanner plugged into OBD-II data link connector.
  • Tip: The OBD-II diagnostic trouble code (DTC) is a 5 character alphanumeric code. The first digit is a letter that indicates the component group, the second digit is OBD mandated or manufacturer specfic, the third digit is a subgroup, and the fourth and fifth digits define the component and basic problem.
  • 4. Locate the throttle position sensor.
  • Throttle position sensor
  • 5. Disconnect the electrical connector from the throttle position sensor.
  • Electrical connector removed
6. Test the resistance of the throttle position sensor (TPS) with a digital multi-meter. If the resistance is out of specifications, the TPS must be replaced.
  • 7. Remove the throttle position sensor.
    Removing sensor mounting screws
    8. Install the new throttle position sensor. Tighten the mounting screws and attach the electrical connector.
  • 9. Erase the diagnostic trouble code (DTC) with the scan tool using the“delete” or“erase” command. Road test your vehicle to see if the check engine light returns.
    Check engine light
  • Tip: If the check engine light returns, repeat the diagnostic process for additional DTCs or take your vehicle to a certified repair shop.
Direct OE replacement
Hope helped with this. Good luck (remember rated this help).
Nov 05, 2009 | Ford F-150 Cars & Trucks
Lands Phones Logo
1,220 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
