Question about GE WSXH208A Front Load Washer
Imbalance The washer "hops" during the spin cycle because of some imbalance?
  • 56 Answers
All front load washers must be very close to level because of the high spin speed
Posted on May 31, 2009
My Zanussi FJD1666w spin cycle isn't working. Any ideas?
Machine spins but stops.. loading imbalance.. try with less load.. or drain pump and valve not working.. check for block..
Jan 26, 2015 | Zanussi FJD1666W Front Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer is knocking in front left when is starts spin cycle. The unit used to stop and re-align but not longer does. The knocking gets louder at slow speed and somewhat improves at a faster speed. What...
The unit is self aligned when all the load springs connecting from the tube to the bottom chassis are intact. When one of them some how gets out of its position or broken, it causes the tube imbalance so it knocks during the spinning. There are about 8 springs distributed evenly from front, sides, and the rear. Need to check these out.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't finish the cycle because of imbalance during spin. It just shuts down, but I have time left over. I need to cancel the wash cycle in order to run the spin only cycle. ATF8000FG
I called a repairman since it had 5 more days under warranty. The problem was the drain tube from the washer into the drain was pushed too far down into the drain pipe. He did have an error message that it was taking to long to fill. Well no wonder, it was siphoning out the water as it drained.
Seems to have fixed the problem.
Nov 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
GE WSXH208A Front Load Washer Logo
111 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
