Question about Refrigerators
Samsung rb215lash refrigerator compartment freezes everything despite the temp control setting at 46 degrees. I bought this refrigerator from a used appliance store and didn't begin using it until after the 90 day warranty expired. it froze everything in the refrigerator compartment from day one for me.
    Sergeant:
  • 296 Answers
Hi
the temp control got stuck during a cooling cycle if you replace the cold control it will solve the problem.
OR
chek this forum ,u will ve an idea regardin ur probs
http://www.applianceblog.com/mainforums/archive/index.php/t-38.html
OR
your thermostat is probably defective. is it an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
however the refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly
hope u ve got a detailed idea
regards
Posted on May 31, 2009
  • Anjana Batabyal
    Anjana Batabyal May 31, 2009
    hi
    damper assembly both pics r given here
Fridge is freezing everything. Tried to unplug to reset, now front panel is blinking and won't do anything else. I have a rb215lash bottom freezer refriderator.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 25, 2011 | Samsung RB215LASH
For no reason, my freezer went up to 56 degrees in a matter of 5-6 hours. I pulled the plug like the manual states because the temp was blinking. That solved the blinking. In 6 hours the temp dropped to 44...
You have either a sealed system problem or a control board problem. It's difficult to know which is which. You will need a qualified technician to determine what the problem is.
Good luck
Jun 17, 2011 | Samsung RS265LABP Side by Side...
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Refrigerator temp too cold. won't stay at 34 degrees.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 04, 2011 | Samsung RB215LASH
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Sep 26, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
