Question about Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook
Turns on but wont go pass the startup screen
My Acer Aspire 5610 will turn on but it wont go pass the Acer startup page, it says press f2 for setup at the bottom but when i press it nothing happens.
  • 1 more comment
  • tmmauldi May 31, 2009
    If i put in the operating system disk or re install, will it erase all of my documents?
  • tmmauldi Jun 01, 2009
    Windows Vista
    I believe that there is a problem with the hard drive, is there a way for me to get files and software from the hard drive using another computer?
  • 35 Answers
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
Posted on May 31, 2009
  • 1 more comment
  • Dan Mertz
    Dan Mertz May 31, 2009
    which os are you using?
  • Dan Mertz
    Dan Mertz Jun 01, 2009
    vista has option in lower left hand corner to repair - select this then select repair startup on next screen.
    if this does not work you can do a reinstall selecting to leave file system intact (no format).your programs wont work anymore, but everthing will be saved to a "windows old" directory on the hard drive;->
  • Dan Mertz
    try booting from os boot disk-when you get to vista install screen click install the installation will attempt to find your hard drive-if it shows a hard drive in the next screen i doubt that its your hard drive causing the problem.you can always cancel the install if you want after this step.if you do a fresh install, there are programs that can recover a formatted disk afterwards;-) Ontrack is one, there are several.the trick with a laptop is you have to have a external drive to let the program copy your recoverd files to-you can also format your hard drive durring the fresh instll and create 2 partitions, both active with the one you put vista on as your primary boot, and make sure you allow enough space on the secondary partition to save all recoverd files on.
Bios password setup for acer aspire 5610
when you start your pc enter the bios setting pressing F2 normally.. once there you can find the security option and bios password is in there type the password you would like and press F12 nomally to exit the bios with saving
Jan 11, 2011 | Acer Aspire 5610-4648 Notebook
I have an Acer aspire one netbook. As soon as i turn it on, it shows the first screen that is black with ACER on it, but it just freezes there. I can't access the computer unless i press F2 and exit setup....
Looks like there is something wrong with the registry database of your computer. Best way to fix is to clean Windows registry using some reliable software such as Reginout and start your computer normally. Also do the following.
> Limit your startup programs
> Uninstall unwanted programs
> Disable background running services
Thanks
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer 3000 Series Laptop Splash screen does not appear at startup when pressing F2 on the post page. Therefore unable to acces bios. Has e-manager but cannot access bios through it either. Welcome all...
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
Jun 19, 2010 | Acer Aspire 3000 Notebook
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
Laptop wont get into or past bios set up screen
check the cpu and memory I had a similar problem with a laptop I replaced the cpu and all is well..
Apr 24, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 boot issue
The Video Chip or VIdeo board was faulty, you need replaced motherboard or video board 9if it has), unless you can find components level repair tech near you.
Nov 27, 2008 | Acer Aspire 5610-4648 Notebook
MY ACER ASPIRE 3002LCIPC LAPTOP WILL NO PROCESS PASS THE WINDOWS STARTUP
Unfortunately your in a state where you need to
1. boot into a dos based application and run a virus remover.
2. slave that drive to a clean master that's protected with virus software
3. blow the drive away and start over.
sorry
t
Aug 28, 2008 | Acer Aspire 3002LCi Notebook
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook Logo
439 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
