Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Camera won't record/ play footage.
I was filming for a project with tapes that i already had footage on. I was taping over some of the old footage. Then i got a moisture condensation thing and i waited it out. Then i a dirty video head. It would let me film a little at a time. So when i was done i went to review the footage and nothing seemeed to record but also nothing was on the tapes like everything had been erased. What is going on.?
  • itshuntbag May 31, 2009
    thank you so much
  • 10,594 Answers
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
Posted on May 31, 2009
Hi! my sony dcr-trv265e can play the tapes via the video and tv but when i re-record over them its just a blank blank screen? so i need anothe tape or can i record over old tapes?
Sony and the other media suppliers do not recommend re-recording over any digital tapes, including MiniDV. Re using tapes can lead to dropouts and errors after only a few times. With MiniDV prices so inexpensive these days (in the grand scheme of things), is there any reason NOT to use new tape? Also, many companies keep all their MiniDV tapes as a kind of stock footage archive. You never know when you might need a shot that you have already filmed, and it saves considerable time and money to pick the tape off the shelf.
Mar 13, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Getting footage from a cassette onto a mac
Sorry but the only way to transfer the tape is to be able to play it in a compatible camcorder or player. Then use one of the analog to digital converters "available on the internet" to transfer it to a PC.
Best bet is to ask some friends if they have an old camcorder that will be able to play that video cassette for you.
Sidenote: If the cassette is fairly new it might already be recorded in digital format, in which case you only need a compatible camcorder or player and a USB or Firewire cable to import it into your Mac
Hope this helps, don't forget to vote if the answers you seek are helpful.
Mar 23, 2010 | Canon Optura 50 Mini DV Digital Camcorder
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Cannot play my recorded films
if the camera is not showing recently recorded clips then the problem is fith the recording system, but if you are not able to view the old recorded tapes the there may the simple defect of head getting dirty. a head cleaning tape would solve the problem
Feb 12, 2008 | Canon ZR300 Mini DV Digital Camcorder
Horizontal lines in my dv tape
TRY USING ANOTHER PLAYER IT MIGHT B YOUR CAM. TRY A HEAD CLEANER
Dec 16, 2007 | Canon ZR85 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Taping over previously recorded tape
I too had same problems its because your tape head is not clean use a head cleaner cassette and play it, your problem will solve
Nov 19, 2006 | Panasonic NV-GS35 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
197 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
