Microsoft Office Excel 2003 for PC Logo
Anonymous Posted on May 31, 2009
Reminder in excel
Hi,I need this help and it is very urgent..Your help will be much appriciated.I need an Excel sheet which can remind me on the current date if i have any task to be completed.Its ok if it has a macro.For eg..I could have spoken to a customer 7 days back and i should be responding to him today. when i open my excel and run the macro i should have the list of customer's names, Invoice number, the last comments and the actions that needs to be taken..
Anonymous
Level 2:
  • Expert 407 Answers
  • Posted on Jun 01, 2009
Anonymous
Expert
Level 2:
Answers
407
Questions
Helped
163200
Points
834
There are a couple of types of spreadsheet - Depending on the size of the data you are working with - filter may the quickest option or Query report.
Your worksheet will contain all your data i.e. Customer, contact no, outstaning actions and due date - You can create a filter aon this set criteria on the due data - as less than or equal to todays date - which will only display your outstanding actions required by today or earlier.
Another option if you have installed MS Query, is to create a seperate report - again using the criteria of due date being less than or equal to today.
Producing this from your existing data is much easier than trying to re-create your data - But I can send you how I would create this sheet if the above explanation is not easy to follow - If you let me have your email address.
4helpful
3answers
1helpful
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
2answers
Delete blank rows in excel using visual basic
have you tried to read in one file and write back in excel format only the non-blank rows?
FORGOT THE PASSWORD
Hi SAKHIE
You need to run a utility, link below
http://www.straxx.com/excel/password.html
2answers
How to hide sheet tabs in MS Excel
Do you mean by Visual Basic / Macro?
if so this is what you need:
ActiveWindow.DisplayWorkbookTabs = False
3answers
Excel password removing
could you please supply us with the version of Excel you are using? it's under Help About Excel
Excel sheet downloadin softwar
Sorry but there is no application for the K550 that can open excel documents.
5answers
Forgot password
Try this link http://www.download.com/Free-Word-Excel-Password-Wizard/3000-2092_4-10249516.html?tag=lst-0-1 It should help you unlock the Excel file and break the password. Good luck
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
