Question about Frigidaire 24 in. FDB636GF Built-in Dishwasher
Inlet valve water doesn't enter frigidaire dishwasher. I get 12 volts at inlet valve. What voltage is required to operate the inlet valve?
  • wwboone Jun 02, 2009
    Over 24 hrs and NO response. This forum sucks!
  • 1314 Answers
SOURCE: Fridgidaire dishwasher won't fill
id replace the fill valve just because the fill valve selnoid is good doesnt mean the valve seat is not sticking
Posted on Jun 03, 2008
  • 3 Answers
SOURCE: Frigidaire Quietclean I "Not filling with water"
Sounds like you might have forgotten to turn the water on to the dish washer... it happens all the time
Posted on Oct 29, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Upper spray arm doesn't move. Replaced inlet
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly: Most modern dishwashers have self-cleaning filters that don't need any routine cleaning. Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
Posted on May 17, 2010
heatman101
  • 43501 Answers
SOURCE: inlet valve for Frigidaire 24
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 26, 2010
  • 44 Answers
SOURCE: hi our dishwasher fills with water and then never
Hello, it sounds like your dishwasher motor is bad. These frigidaire motors go out quite frequently. To replace it, pull out dishwasher and underneath, just disconnect the mount and screws and it'll pop right out. You can probably get a motor online for 100 bucks. Hope this helps,
Rich
Western Appliance Repair Meridian
Posted on Dec 01, 2010
Miele dishwasher doesn't start Shows inlet
I am working on a similar problem. You need to refer to different info depending on the model. Do an internet search on
2011-11-25_043923_g600__800_miele_service_manual.pdf
You will probably find a lot of "experts" blowing smoke but this should help keep them honest.
Jan 24, 2013 | Dishwashers
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
Dishwasher doesn't have water going in but there is water going in the hose from the tap
Possible failure of the inlet Valve or that the command voltage for the inlet valve to open is absent from the program controller unit.
So you need to check the valve first ,remove and check the valve with voltage, clean if clogged.
If not the program controller is defective.
Sep 06, 2011 | Haier Dishwashers
Dishwasher begins cycle then switches to rinse - no water seems to be entering the washer
Most possible that the inlet line is clogged at the filter or that the inlet valve is struck or faulty.
Please make sure with a voltage check if the inlet valve receives the voltage to it, if not the program controller is faulty.
Finally check the water line pressure at the inlet.
Feb 04, 2011 | Fagor LFA086XL Dishwasher
There is no water going into the dishwasher.
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 08, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
Dishwasher will not intake water
See if the float in the front corner inside the unit moves up and down freely and makes a "clicking" sound when moved. If there is a clicking noise, the float switch is probably okay. The switch can be tested with a volt/ohm meter by removing the lower access panel to get to the switch. Some units have an actual water level pressure switch attached to the pump housing instead of a float and switch. These switches can plug up with soap residue causing a no fill or overfill condition.
The problem is more likely the water inlet valve. These valves go bad frequently for a variety of reasons. It is not worth the risk of a valve failure and possible flood to take apart and clean an inlet valve. Replacement is the best solution. In most conditions, the inlet valve will need to be replaced every 4-6 years.
Go here for> Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
Frigidaire Parts Specialist - www.RepairClinic.com
Feb 12, 2009 | Frigidaire Dishwashers
The dishwasher make noise but no water is comming out
Hello
Welcome to Fixya
My name is Huum,
here are a list of the four most common reasons for this problem!
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/tohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Defective water inlet valve
If there is 110v across the two wires on the water inlet valve when the machine is set to fill, the valve should open and the water should enter into the machine. If the water does not enter, the valve is defective.
Float Switch
The float switch allows water to enter into the machine to a point where the float will rise up off of the switch and disconnect power to the water inlet valve. If the switch is defective or the float is stuck in the up position, the water will not enter into the machine.
Water Source Turned Off
Check to ensure the water source is turned on and water is getting to the water inlet valve.
Thank You For trusting us with your question
Please remember to leave a rating before you leave
Huum
Dec 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Since no one wanted to offer any advice, I have chose to call the repair service.
Jul 24, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
