Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki bayou 400 stalls and wont start
If you start it it runs fine then al of a sudden it will chug and stall like it floodeds out and wont start but if you let it sit for a little bit then try it it will start and run fine
We have a 2000 Kawasaki Bayou. the Bike will stall when the brakes are applied and the bike is in gear...you have to keep feathering the throttle to keep it from stalling. there are also times when you start the bike ( happens more cold) ....give it a little throttle and it revs very high...we shut it down worried it will hurt the engine. Any thoughts?
Posted on Sep 05, 2011
    Problem Solver:
  • 6 Answers
The Choke may be stuck or left on.
Posted on Jun 03, 2009
  • Vladimir Feb 26, 2011
    check your valves and avoid ridding it because your valve will break. causing the exaust chamber to not open then your pistion will not be able to compress the air in the combustion chamber. after that it will not electricaly start or pull start. when you go to pull start it it will be so hard and you will snap the string. so dont go far from home with it.
My Kawasaki kvf 400 4 wheeler wont start because the neutral light wont come on even if it is in neutral. it pull starts fine
There should be shift sensor there or a shift actuator to check.
Some Kawi manuals if you need them: Kawasaki ATV
Jul 15, 2017 | kawasaki Motorcycles
2007 Cadillac 3.6L chugging then stalled while driving.
You need to address those misfire codes, have it tested again.
Mar 21, 2017 | Cadillac Cars & Trucks
Car stalled. restarted and did a
try blowing out all the fule lines and changing the fule filters the lines may be blocked up also check the fule tank vent if this is blocked the pump cant **** fule from it
Mar 07, 2010 | 2000 Dodge Intrepid
400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
Sep 08, 2009 | 2004 Suzuki DR-Z 400 E
2002 kx 250 2 stroke wont start
sounds like too much oil in the mix add more gas & clean spark plug
Cheers Rob
Jul 21, 2009 | kawasaki Quad Bikes
My kawasaki 400 bayou runs but doesnt have enough power that it u
I found all spark plugs do not work well in the Bayou, especially NGK....try a champiion spark plug..it may fix the problem.
My Bayou use to stall all the time with the NGK spark plug, but runs good with the Champion spark plug.
May 10, 2009 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
683 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
