Question about Roper RAX4233PQ Top Load Washer
ROPER 4 CYCLE 2 SPEED DOES NOT AGITATE OR SPIN
Machine fills with water and drains out. Does not agitate during wash cycle and does not spin when in rinse cycle. Water drains out but the clothes are very wet as it does not spin dry.
  • 56 Answers
Disconnect power should be a motor coupling broken you take off the cabinet, two phillips head screws left console bottom on back and right console bottom left on back and pull toward you and rollback the console two funny looking brass colored springs insert screwdriver into spring and push back toward back of washer and it will jump out. disconnect the lid swithch and lean cabinet out and looking down inside at front bottom slide out 2 inches to remove cabinet. then two black clips that hold pump on and then two screws and same except larger clips that hold motor on remove wiring harness and lift motor out and youwill see coupling either broken there or on transmission replace with part number 285852A from 1-877-262-1479 to put back on use hammer and 3/8 or 7/16 socket and extension and hit litely untillyou push metal center onto motor shaft then repeat for transmission side put rubber coupling on transmission side and line up motor and doall in reverse to put back together. tip on cabinet clips set in place and push down with heel of hand to snap into place
mike
Posted on May 31, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Won't go to spin cycle-water still in
sounds like your lid switch is defective. if it will fill and agitate but not drain/spin, the most common problem is the lid switch....your machine thinks the lid is open
Dec 29, 2008 | Roper RAX4232KQ Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Roper washing machine that will fill with water, agitate, and stops. I replaced the lid switch assembly and tried it again. Same thing, but one step farther. It went past the agitate and...
The black dust is from the motor coupler. It is normal to have some under the unit. If it stops completly and you chaged the switch check the lid adjustment if the lid is loose it might not make the switch all the time.
Apr 24, 2008 | Washing Machines
Roper RAX4233PQ Top Load Washer Logo
448 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
