Question about Jenn-Air JCD2389G Side by Side Refrigerator
Freezer works but refrig has 60 degree temp .evap coil is caked
I have a side by side jenn air model jcd2389ges and the evap coil when I take the freezer back cover off is totaly frozen .I want to change the defrost adaptive board but do not know where it is hidden .could it be in the refrg section on the ceiling that house the temp slide controls? if so ,How does this housing come down and where under there is it located .I see white insulation. does that come apart? I have the same problem with the right side (refrigerator side) warm but left side (freezer) is working fine. Prior to this the Jennaire refrig was making a rattling noise above the filter in the refrig side. jenn air jcd2389ge fridge side not cold does not appear to have cold air coming in even when damper door is openned manually
    Novelist:
  • 103 Answers
Hi: Did you check the defrost heater itself? I checked Jennair and Sears parts to no avail. If you didn't check the heater it will be at the bottom of the freezer behind where you removed the back cover. A glass tube with a coil in it. If the coil or tube is broken replace that insead. I hope I helped, Jeff I found a website with the defrost timer, but not the location of the timer on the fridge. http://www.appliancepartsworldwide.com/store_SearchResults.aspx?S=1131392&ST=PBM
Posted on Jun 01, 2009
That rattling noise is the same noise i got when my adaptive defrost control failed; 2X's! it is where you suspect. in the firg, highest back right hand corner. pull the plastic shield forward careful not to break the rear clips and remove. loosen two philips screws behind the light bulbs (you can take them out if you want), and remove 3 x 1/4 socket screws. it is in a white plastic housing sitting in the right back compartment of the plastic piece you unscrewed. you can get the part at repairclinic dot com for $70.
Posted on Nov 03, 2011
MY JENN-AIR REFRIGERATOR #JCD2389GES IS NOT COOLING ON THE REFRIGERATOR SIDE. THE FREEZER IS OKAY. THE REFRIGERATOR TEMPERTURE IS 60 DEGREES F.
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Oct 30, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JS48FSDBFA. The freezer works fine but the fridge wont get below 46-47 degrees. What could it be.
May 21, 2010 | Jenn-Air JCB2280HES Side by Side...
My Jenn Air refrig model # JCD2389GES is not cooling on the refrigerator side but is fine on the freezer side.I changed the thermostat and was good for 40 days,then the nightmare started again.
the problem is in your freezer
you need to opaen the wall inside the freezer and see if there is ice build up on the coil.
if it is frozen heard you need new thermostat or heating element. check it first and let me know what you see.
open the back wall (the bottom one)
Feb 07, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air side by side refrigerator Model JCD2389GES is still making ice, food is still frozen on ice making side, but the refrigerator side is not cold, milk is souring rapidly and vegetables are turning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 09, 2009 | Jenn-Air JCD2389G Side by Side...
Warm refrigerator
Check the freezer fan.
Is it running?
If not, replace fan motor.
Check the damper doors in the fresh food side.
Does air flow through?
Mar 08, 2009 | KitchenAid Refrigerators
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
682 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
