Question about Great Outdoors 3600G
I have a Great Outdoor smoker that won't get hot.
I have a "smoky mountain series" by Great Outdoors. The last time I fired it up the high flame was about as hot as the usual medium flame. Tried three different tanks all with the same result (max temp was 190F). This has happened twice previously, but was solved after disconnecting the tank and re-connecting. Any ideas? Smoker won't get hot. max temp 190 degrees . meat not cooking. Same problem as last writer. mridr1@hotmail.com
  • 4 Answers
I had the same problem with mine. I took the burner assembly at the knob apart and cleaned it and that worked for me. The grease from the meat dripped down on the gas orifice and hardened reduced the amount of gas being jetted to the burner. Hope this helps
Posted on Jun 15, 2009
  • 4 Answers
This might sound too simple, but I've read on some bbq sites that if you open a "new" propane tank too quickly there is a built in saftey valve that closes, try opening the tank valve very slowly
Posted on Jun 08, 2009
Can I buy a simple sleeping bag for all of my outdoor use?
Technically, there are 3 types of sleeping bags for various uses outdoors - trail, trekking and mountain. Trail bags are great for short trips and ideal for inexpensive sleeping bags. Trekking bags are designed for longer use and are usually much more lightweight. Lastly, mountain sleeping bags are especially lightweight and are made with extra insulation.
Aug 05, 2012 | Camping, Backpacking & Hiking
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
I need a regulator for a Great Outdoors - Smoker
gas regulator are gas regulators so go to a hard ware shop that sells BBQ /outdoor cooker equipment,
take yours along as a sample and get a new unit
Apr 25, 2017 | Grilling
try turning the gas nob almost to the off position this worked for me
Apr 28, 2009 | Great Outdoors 3600G
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
Need manual for Great Outdoors Gas Smoker
Company went out of business.
Dec 17, 2008 | Grilling
Electric dryer keeps shutting off...
Be sure that there is a LOT of air coming out outdoors first. If there is, the hi limit thermostat is now defective from the abuse of your fire hazard, I mean clogged vent. (same thing) If not, the vent is still not clean enough. If it's flexible duct, replace it with solid duct. You could also have a clogged up lint screen, (fabric softeners commonly clog the screen) or the fan in the dryer may also be clogged up.
Jul 02, 2017 | Kenmore 64852 Electric Dryer
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Smoky mountain series propane smoker
Solution #1 is the answer -- replace the regulator. The problem is that the regulator is stuck closed. You can either replace it, or pop the little metal cap on the top off and adjust it. (Use a large philips screwdriver). Do a full turn counter-clockwise, and then 3/4 of a turn clockwise.
Oct 31, 2007 | Grilling
Grilling Logo
873 people viewed this question
Top Great Outdoors Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Great Outdoors Grilling Expert? Answer questions, earn points and help others
