How to set up on mac
SOURCE: download software
You can download the driver from the following link :
http://driverscollection.com/?file_cid=390169192057c4f19a60c24a889
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: Settings on Linksys router for the DCS 5220 to
Configuring your Linksys router for remote desktop is a task that's
needed before you can access your computer from outside the network. If
you plan to connect to your remote desktop machine from the Internet,
you need to configure the router to allow traffic to the PC. Linksys is
a common router used on home networks for wireless and LAN
configurations. Configuring your router to allow port forwarding to a
remote desktop only takes a few steps through the graphical user
interface.
SOURCE: How to set Static local IP Address for D-link DCS
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
SOURCE: how to setup aztech router
Install the installation disk of the ipcamera. Configure the ipcamera base on your requirements. Then install the ipcamera on the position you require.
SOURCE: Wireless installation for DCS-5220
Make sure your wireless router's user name and password is the same with your camera's wireless user name and password and also same security method
