Question about LG CU500 Cellular Phone
Not reading memory card
I purchased a one gig lexar micro memory card for my LG phone, and it is not reading it.  when i check memory, i continue to get the "card not ready" signal.
any solutions?
  • 8 more comments
  • Anonymous Nov 02, 2007
    I have a 1GB san disk card and still get not ready
  • Anonymous Nov 25, 2007
    I bought the so called great "sandisk" card and still am having the same problems.
  • writer213 Dec 13, 2007
    i put a micro sd 1 gb memory card in my phone and it does not read it?? once in a while it will read for a few days and then suddenly it stops working???..
  • nacho libre Dec 18, 2007
    my phone just does not want to read my memorycard
    i keep getting "card not ready" and its startin 2 fustrate me.
  • Anonymous Apr 17, 2008
    same problem here. works from time to time but not often
  • Anonymous Jul 04, 2008
    I bought 3 separate types of 4gb micro sd cards for my phone and not a single one worked. They all had the same issue; the computer would not recognize it when I plugged it into my card reader. I have a 2 gb PNY that works just fine, but so far Kingston, San Disk, and one other all failed me.
  • dirtbike_boy Aug 18, 2008
    I PUT IT in the right way and it still dont work its a lexar micro sd
  • Anonymous Feb 06, 2009
    I got 1 gig two and wont work
  • Anonymous Feb 23, 2009
    i tried all the listed solutions, and they all failed. my LG is pissing me off
  • 3 Answers
Hi all. Just fixed this with my phone. Copy all the data you have on the portable storage device to a new folder on your desktop (just create one). Then open 'my computer', right click on the device, then click format. After that it will pull open a new window and it will have a format form option. It will say either FAT or FAT32. My sister's LG Trax wouldn't read the FAT32 but would the FAT. Then reload the card and give it a whirl. It worked for me on my cu 500 too.
Posted on Jan 05, 2008
  • 3 Answers
When your on your main screen, right after you open your phone or press end call button. press 277634#*# and it will take you to the phones test page. go down to port settings and go down to mass storage press okay. then go down to mass storage remove. this usually gets the phone to read your card. sometimes you gotta play with it but it works
Posted on Feb 04, 2009
  • 52 Answers
Brand does not matter here, a brand name only gives u advantage over warranty or assured quality for long term use.
And the reason why the card did not read could be that the phoe does not support 1Gb of mem. Try something lower say 512 or 256Mb.
Posted on Dec 05, 2007
I had the same problem with my LG CU500 when I bought a 1 GB Kingston card.  Research turned up this link and although it only talks about Kingston as opposed to the recommended SanDisk I would say you are going through the same thing with the Lexar card.
http://forums.cingular.com/rss/message?board.id=LG&message.id=13491
I ended up getting a SanDisk and it now works without errors.
Posted on Oct 30, 2007
You need a sandisk micro sd card lg cu500 only accepts that brand
Posted on Oct 28, 2007
  • 490 Answers
    might be there is some problem in ur memory card..u  just do one thing put ur memory card in memory card reader ..try to find where is the problem...& also try to use ur memory card in some othr hndset compatible with same memory card...& if the problem still persists..then u nedd to change ur memory card aas no othr option is left..
Thanks
Gizmo1
Posted on Oct 23, 2007
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
EMachine H3065 cannot find Lexar 4BG micro SD card using adapter
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jan 02, 2009 | LG CU500 Cellular Phone
Axim x5 sd not reading
I would think it is having more trouble with the adapter than the actual card. It could also be the storage size of the card that is the problem as well. Try a regular 2GB SD Card and see if it works. If it does, then it is probably just the adapter.
Jan 01, 2009 | Dell Axim X5 Pocket PC
Samsung Trace t519 Micro SD
I have this phone to. I remember reading a long time ago, sorry I can't source it, but anything over 1gig the phone will not recognize. I have had 1gb sandisk and 1gb Lexar in my phone no prob. Try getting a smaller size card.
Sep 17, 2008 | Samsung SGH-T519 Cellular Phone
LEXAR MICRO SD CARD WITH LG CU 500
I have found that only my 1 gig Micro sd card works, I also have a 2 gig and it does not recognize it at all. I have been told the CU500 only supports up to 1 gig.
Jun 05, 2008 | LG CU500 Cellular Phone
Micro sd
i think that you should use amemory card of lower memory.
Jan 31, 2008 | LG Shine KE970 Cellular Phone
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
LG CU500 Cellular Phone Logo
746 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
