Question about Whirlpool Calypso GVW9959K Top Load Washer
The Calypso washer and the CI error code!! What to do now?
I have the Whirlpool Calypso washer. It was working fine and then started a CI error code. The washer will no longer work. I have tried all of the manuals troubleshooting ideas and nothing seems to change. Is there anyone that has had this same problem and what did you do to fix it? BV
SOURCE: It diplays OB error code
The loud humming noise is likely the pump. These pumps have a bad history with stripping the gears (the original code likely Ld? = Long Drain).
The pump is easy to replace, but make sure you find the replacement pump with metal gears (the original has plastic).
Posted on Jun 13, 2008
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
SOURCE: What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Posted on Sep 02, 2008
SOURCE: F 11 error code on Whirlpool Duet - Serial Communication Error ?
I believe EVERY machine will have this F11 error eventually. Here is what fixed mine. Remove the top cover by removing the three 7mm screws on the back of the machine at the top. Slide the cover to the rear and lift off. The CCU board has 2 relays on it. They have white plastic covers. One is labeled K4 and I believe the other is K2. There are five legs on each relay soldering them to the circuit board. Remove the circuit board from the machine. It is the one you can see with the top off in the back of the machine. Unplug all the connectors. Unsolder the 2 relays...brand name Omron. With a jewelers screwdriver carefully remove the plastic cover on the K4 relay. Examine the contact points on the normally open contacts and I will guarantee they will look dull and burnt. They should be bright and shiny. You can burnish the contact points lightly and clean them with electrical contact cleaner. If you take off the cover of the 2nd relay you will see the contact points are nice and bright and shiny. Swap the 2 relays and resolder them on the circuit board. While you have the board out, take a pencil eraser and rub it on the contact points where all the connectors slide onto the board. Spray the electrical contact cleaner to wash any residue away. Carefully reinstall the circuit board and replace the top cover. Our machine has done dozens of loads since I did this with no more problems. I expect another failure at some point when the points deteriorate on the swapped relay. At that point I will try and find replacements for both relays. The K2 relay apparently has less voltage going thru the contacts and does not fail. If you feel real comfortable, you can check the "wiping" action of the points by manually operating the relay when you have it out. I adjusted mine to give a bit more wipe on both relays. I hope this helps...it worked for me!!
Posted on Jan 10, 2009
  • 99 Answers
SOURCE: whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Posted on Feb 06, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
What is era Code CI on a Calypso washer
A CI is an to high amp draw on the motor. In my experience it could mean your motor is bad, or motor control board is at issue. The only way to really check is to have an amp meter to see if the motor is drawing to many amps.
285917 MOTOR ABOUT $250
8571359 CONTROL BOARD ABOUT $200.
The biggest issue, is you may also have a transmission locking up, basket drive issues, bearing issues, etc causing the motor to pull the high amps.
May 29, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
WASHER NOT WORKING CODE CI
This means Instantaneous current overload.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading the washing machine may cause this.
for more info download the manual at
http://www.manualslib.com/download/193839/Whirlpool-Calypso-Gvw9959k-0.html
see page 51 on error codes for this unit
Nov 06, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso is flashing C1 when I try to start a load
Hello
C1/CI code indicates instantaneous current limit trip. This instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.This may signify problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem. Press STOP/CANCEL to clear the display. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine won't work it says C1 message. pls advice.
On Whirlpool Calypso washers that is probably not a "1" but is the letter i. The code "CI" is the fault code that indicates "Instantaneous Current Limit". Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector (fuse), or motor controller. Overloading the washer may cause this condition. Press stop/cancel to clear the display. Hope this helped you.
Jul 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso #110.2262101 SN-CL3602829 CI error code
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool calypso washer and it is showing an error code of C1, what does this mean and how do I fix it
CI (an "i", not a "one") and OB are related - overloaded, the washer's motor controller will draw too much current and either the average current will peak ("CA" error) or the instantaneous current will spike ("CI" error). OB - out of balance - indicates of course a load that is not balanced, or is too heavy. Wash less items and see if the problems lessen. That is what we have had to start doing, but we still can wash a BUNCH of items in this type washer!
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso model 11022086100
Thermal overload protector is mounted on the motor. Normally the motor is replaced.
Jan 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
190 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
