Question about Polaroid PDV 0707N Portable DVD Player
Connect PS2 to Portable DVD Player?
I want to hook up my PS2 and/or Gamecube up to my Polaroid PDV-0707N Portable DVD Player. What do I need to buy to be able to do this?
  • juliet_hays May 31, 2009
    huh? Pics would be nice.
    Problem Solver:
  • 16 Answers
I've done this before, i had to buy double female R.C.A. connectors (3) of them sold individually if I remember correctly, and then proceed to connect the 3 "male" ends from the PS2 cables to the 3 double "female" connectors i bought (best buy, meijer, radio shack, etc.) and then connect the 3 "male" ends of the R.C.A. cables that came supplied with my portable DVD player to the other end of the 3 "female" connectors, and finally connected the other end of the (DVD supplied) cable into the portable DVD player. hope this helps, and i apologize if it sounds a bit confusing, just trying to be as thorough (i have no idea if i spelled that right) as possible. Keep me posted if this helps!
Posted on May 31, 2009
  • jjallen5150 Jun 01, 2009
    Unfortunatly im unable to supply any pics. for you,sorry, but if your confused as to what im talking about let me know where you got lost on what i tried to describe and ill try my best to further assist you as best i can. Sorry once again.
  • jjallen5150 Jun 02, 2009
    O.k., I guess the best way I can describe this to you is as follows: both your PS2, and yor portable DVD player "should" have the red, white, and yellow audio/video cables that came with them when you bought them. They are "male" style connectors designed to be plugged into the audio/video ports of a television. Now, what you need to buy is "female" adapters, 3 of them, they have 2 ends, so you can plug your PS2 cables into 1 side, and your portable DVD players cables into the otherside of the "female" adapters. Let me know if this helps any better.
Power goes off going down the road when we hit a bump or when its playing movie
Check to see if the battery pack is loose. I used packing tape to secure mine in place and it does not have this problem anymore.
Jul 28, 2011 | Polaroid PDV 0707N Portable DVD Player
The used dvd player I just bought read no disc is there anything I can do?
Hello noralpn and welcome to FixYa. I see your having difficulty with your Polaroid Portable DVD Player. This problem commonly occurs with used products as some people will try to sell (problem devices) to other people since is no longer of value to them but let's try a couple things to see if we can get it working. First check to see if the disc you are using is clean and free of dirt and or foreign debris. If it is not you can clean the media with water or a lens cleaning solution followed by wiping it dry with a microfiber or other soft cloth. If you feel this is not the issue the next course of action would be to clean the laser lens inside your portable DVD player. This can be done by adding a very small amount of water or better yet a lens cleaning solution to your cloth and gently wiping the laser lens inside your device. Please make sure the lens is dry before attempting to operate the DVD player again. If this does not solve your issue I would have to tell you to contact Polaroid for further service in which I have provided the number below.
Polaroid Customer Service
1-800-343-5000
I hope you found this helpful noralpn and thank you for using FixYa.
May 06, 2011 | Polaroid PDV 0707N Portable DVD Player
Hi i want to know how to connect my gamecube to my portable dvdplayer
I'm going to assume you are trying to be able to play both gamecube and the dvd player on one tv. Not at once, but I'm guessing you think you can't hook both to the TV. If you no matter what big tv it is, you can connect it to your tv.
If your trying to connect the gamecube to the dvd player then you need to have inputs and outputs on the dvd player itself. hook the video and audio of the gamecube to the input of the dvd player and the ouput of the dvd player to the input on the tv
Aug 09, 2009 | Pyramat PM450WR for PlayStation 2,...
Player freezes partway through movie
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Sep 06, 2008 | Polaroid PDV 0707N Portable DVD Player
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
1-866-400-5168
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
Polaroid PDV 0707N Portable DVD Player Logo
209 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
