Question about Frigidaire Affinity ATF7000E Front Load Washer
My frigidaire affinity wont start door Lach won't hold "DR" error
The washer door wont shut or lock My frigidaire affinity is only 2 years old. Error code says door is open, and washer will not start. Serviceman replaced latch today, and washer stays locked when plugged in. He wants to replace the control board. is this nece$$ary??? Latch won't grab so panel says DR and won' start--- I am sure problem is in the door latch switch how do we R&R this part ?
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Why is my washer displaying a "DR" when I push start?
  • 1 Press any button on the display panel.
  • 2 Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
  • 3 Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
  • 4 Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
  • 5 Close the door and re-select a new wash cycle and "Start."
  • Jul 25, 2014 | Frigidaire Affinity ATF6000F Front Load...
    Frigidaire Affinity ATF7000E DR error code
    Good Morning Friend,
    I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Error code DR comes up on my Frigidaire Affinity and won't keep running
    It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
    Here is a link to the part if you need it.
    Here is a link to a service manual for your machine that will take you through the testing and repair process.
    http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
    Oct 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
    Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
    Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
    I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
    You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
    Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
    May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire Affinity - Code DR - Washer wont start
    Dear G.Arnold,
    ngfam at you service
    When you get an error its best to call service
    Yes sounds like you need service!
    Call A&E Factory Service /They service nation wide
    And are available 24/7 for making appointments!
    If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
    Happy to assist you,
    Neil
    PS.Before you sign off!
    PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
    Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Affinity/dr error
    dr code means door not closed
    get some crc spray and spray into lock on machine
    that will lube the workings and should fix problem
    Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
    AFFINITY ERROR CODE
    It means the door isn't shut all of the way.
    Aug 17, 2007 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    263 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
