This is Absco Sheds and the page that gives you instructional videos for assembling their sheds. (Plus preparing the site, and constructing the concrete slab)
To write out instructions would take many pages. I suggest you get a manual. Here are some general tips though. When removing items write down everything you do for install reference. Label all plug ends with different coloured electrical tape not only on the plug, but on the component it goes to (match up on install.) Put everything you remove in boxes and cans. there is nothing like trying to find a lost bolt, etc. during install!! Look carefully at new and old engine. Anything different on new one must be replaced with old engine parts, so it matches up when installed. If replacement is used, check for any and all oil leaks it's far easier to deal with them out of the vehicle. As a rule, if replacement engine has over 100k on it, I replace the timing chain. Most are well worn by that time.If you did not hear or see the replacement run, check spark plugs for good burn pattern and colour, if you find burned residue, you don't want that engine!!! Do not forget to repalce any lost fluid from trans, transfer case etc before firing it up!!!
email customer service at [email protected] and she will either mail or email you the instruction manual...told that the web site is under construction
You will need to call Olympus to have them email you the Digital Wave Player application files. Their telephone number is 888-553-4448 option 5 then option 2 for digital voice recorders.
