Question about Kenmore Washing Machines
Washer fills with water, stops completely and does not go to the next cycle
Our kenmore elite top load washer fills with water but does not go to the next cycle. help!
  • Tom
    Tom May 11, 2010
    Can you move the program on manually
  • 15,935 Answers
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
