Question about Peavey Pv 2600 Power Amplifier
Peavey PR15-D Powered speakers, Power on but no sound.
Power LEDs come on, no sound. The other one works fine so I ruled out the cables and dj system. Took it apart, nothing obvious on the circuit boards. I'm at a loss.
  • Anonymous Mar 13, 2014
    At gigs, my backing music cuts in and out or the voices become distorted. I plug both the right and left cables direct into the 2 jacks at the back of the mixer. Using new cable leads.
    President:
  • 1,138 Answers
Check for impedance ( resistance) in ohms on the speakers disconnected from the circuit using a volt/ohm meter. I think the woofers are 8 ohms and the tweeters are 8 ohms. Also check for bad solder joints where the jacks are soldered to the circuit boards.
Posted on Jul 11, 2009
No sound out of my mack th-15a
As Tom Jones sang 'It's not unusual....' The amp has probably gone and you need to get it fixed. These are not the most reliable and I would suggest getting something better from another manufacturer if you can afford it, perhaps a local shop would do you a trade in if they can fix it?
Nov 11, 2013 | Mackie TH-15A Active DJ Powered THUMP...
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
Th-15 power light comes on and goes off but there is no sound
short circuit in secundary of the power supply or power amps damaged.
Jan 07, 2012 | Mackie TH-15A Active DJ Powered THUMP...
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
I am having trouble running an american dj quad gem in dmx mode. I have other lights that are working fine.
If by chance teh light is on the end of a long DMX cable run, read about putting a terminating resistor at the end of the chain. You say you are having "trouble"... that doesn't tell us anything that we could help you with.
Apr 23, 2011 | American DJ Supply American Dj Quad Gem...
Hi I have a pair of Mackie SRM450s. When applying power I get a high pitch squeal whether I have speaker leads connected or not. After flicking the low cut or contour buttons on and off it then goes away....
Make sure you have ALL interconnected parts of the system powered from the SAME receptacle or power conditioning module. This MAY require you running an extension cord back from where your speakers plug in to supply power to the mixer. The ground bounce in power wiring in building can cause feedback or even destroying the sensitive input circuits of your system. As an electrical engineer I see these problems frequently. I think they should include this information with sound equipment user manuals, but they don't and people have trouble and damage their equipment. Doing this MAY also fix the problem you are having.
Apr 16, 2011 | Mackie SRM450 V2 Active DJ Powered Speaker...
Hi. I have a Marshal MG10CD amp. It was working fine, till a few days ago, when it suddenly stopped functioning. The amp gets power supply, as you can hear static when switched on, however, when the...
Check for a dry/cracked solder joint where the 1/4 inch phono input jack connects to the printed circuit board. Solid state Marshalls are renowned for this.
Feb 23, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
Boss br-8 digital recorder wont load up. powers up but no program
This Sounds Very Bad Do You Have Experience With Taking Apart Computers? If So You May Want To Open Up Your Br-1180 And Remove The Hard Drive And Put It In Your Computer And Copy All The Data Off Of It. I Also Would Recommend Calling Roland They Are The Most Helpful People In The World.
www.Myspace.com/CrossRoadsToNowhere2007
Dec 28, 2008 | Boss Micro BR Digital Recorder
Peavey Pv 2600 Power Amplifier Logo
293 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
