Question about Panasonic PT-LB10VU Multimedia Projector
Projector is showing red as black
The projector is showing red as black
    Problem Solver:
  • 17 Answers
Red Lcd panel is failing, your cable is bad, or broken pin on input.
Posted on Jul 17, 2008
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Why is my Sony 3lcd projector not showing the color red?
I hope its on warranty because that sounds like a circuit board problem. Was the replaced lamp the original specification?
-GWOOD
Jul 14, 2014 | Office Equipment & Supplies
When we do a presentation the Red shows black and orange shows green what can be the issue
have you selected the colour mode,
sRGB: Matches the color palette of standard sRGB computer
displays.
Feb 23, 2011 | Epson EX51 Projector
The projector does not show the color red. It shows it as black or on a black background shows nothing at all. Can you help?
It could be 3 things--
1. You need a new cable
2. This is unlikely, but the red segment could be off the colorwheel, but if this was the case the wheel would be way out of balance and the projector would be vibrating like crazy.
3. The "color ramps" or colorwheel index in the hidden factory menu may need to be adjusted.
Sep 15, 2010 | InFocus LP70+ Multimedia Projector
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Cheers
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Red does not show up
You have a break in the VGA feed to your projector, try another lead and try menu see if it is missing from there if not it is the lead.
Marc Engineer
Feb 13, 2009 | NEC VT570 Multimedia Projector
Connection Identification, experiencing no Sound
Thank you for your help I visited a Sony retail outlet yesterday and they explained that to obtain sound you have to go through a sound system using the red connection because they is no sound / speakers build into the projector.
Feb 13, 2009 | Sony VPL VW10HT Multimedia Projector
Open Questions:
Panasonic PT-LB10VU Multimedia Projector Logo
294 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
