Question about Canon ZR85 Mini DV Digital Camcorder
Won't accept a tape
I can put a tape in the recorder, close the thing that holds the tape, but the machine will not accept the tape. i have tried several different brands of tapes. I have the same problem. I put a tape in and the camera will not close. It just gives me a few beeps and says remove tape. I have tried several new and used tapes with no luck. Has always been a good camera with no problems. I hope it can be fixed!!!!
  • 274 Answers
SOURCE: tape won't load
There are different designs on how this works. One design there is a small pin inside that detects if you have the right tape installed. It has a very small spring which allows it to move back and forth it may have broken with normal use. (it happens) With a small flashlight look very carefully inside. You may or may not be able to see it. It may be located under the alum carrier and hidden. Worth a look. If you find it try to reattach the spring if in fact you see it. But I doubt you can because you need to get goo access to it. In any case, you most likely will need to take it in for repair. The tape carriers for these cameras are fragile and easily damaged. Wish I could give you and easy fix.
Posted on Sep 16, 2007
  • 3 Answers
SOURCE: "REMOVE THE CASSETTE" displays when I put in a tape.
Same problem appears on another thread at fixya.com
http://www.fixya.com/support/t260350-tape_acceptance
villagidit posted a solution there that worked for me.
The same problem exists apparently on the ZR200 which is where villagidit found the solution.
Basically all it involves is thumping on the side opposite the display. I tried the thump once with no effect. I gave it two more thumps and the problem went away. Not really a solution. But it was satisfactory for me to be able to get the camcorder working long enough to transfer all my DV video onto DVDR..
Seems something comes loose in these Canon camcorders (presumably a connector of some sort.) There are 10 votes for this solution on the other thread as of 5/19/2008.
Posted on May 20, 2008
SOURCE: won't except tape
I have a ZR100 that did the same nearly the same thing - but it was only beeping twice. I followed the advice another thread suggested - I banged it twice on the opposite side from the door but it didn't fix it. Then I banged it twice on the side with the tape door.... and now all is well!
I couldn't believe that "fixed" it. Like banging the ol' tube color TV on the side to fix the picture. Maybe it is short lived, but if it holds for the rest of this year until the camcorder Christmas sales begin, I'll be happy!
Posted on Jun 24, 2008
SOURCE: Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Posted on Aug 17, 2008
SOURCE: canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Posted on Nov 17, 2008
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
The machine won't erase my tapes? Is there a chance it could be a faulty machine?
Does the erase light come on and the tape rewinds? Or does it just beep when you try? Could be a bad erase switch, sometimes pressing harder will do the trick. If it just beeps, try another tape.
Jul 18, 2011 | Sanyo TRC-7060 Desktop Cassette...
Sanyo Stereo Cassette Recorder M7300K will not record and record button vey hard to push down
Make sure the tape you are trying to record to is not restricted (unrecordable or pre-recorded). You can look at the tabs on the top narrow band and if they are punched out the tape will not accept recorded material. (you can put scotch tape over the hole and still record but only if you are desparate!)
Oct 22, 2009 | Audio Players & Recorders
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
Wont take tape
I just posted that I had the same problem with the Elura 100 not taking the cassette, although the compartment will close without a cassette. And I did have the problem with the left wheel rewinding, then the beep occurs.
I was tinkering a bit. I decided to take some video on the SD card, and I let it record for a moment. After that, I went back to trying to get the cassette compartment closed, and it worked! Almost like the camera needed reset.
We'll see if it stays corrected!
Prior to that, I have tried using a can of air, loading a new cassette, etc. And I DEFINITELY did NOT have any condensation!
Hope that works for ya!
Jan 31, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Sony video8 won't accept tape (door won't finish closing)
Sony DCR HC 42
I have the same problem as gskillman
Sony says it qualifies for a fla rate repair -- $201 plus taxes!!! Say what? This camera is only a couople of years old and has hardly ever been used.
Jan 11, 2009 | Video Cameras
Canon ZR85 Mini DV Digital Camcorder Logo
59 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
