Question about Sony KP-57XBR10 57" Rear Projection Television
57xbr10w pops & sparks under one of the lamps & shuts off
Sony 57xbr10w makes popping sound & sparks under one of the lamps when turned on, then it turns itself off.
  • 10,594 Answers
The Lamp (CRT) got shorted / leaky that gets spark / arcing and requires replacement. TV is an old model and I'm not sure that CRT is available any more.
Posted on May 31, 2009
(TV arcing crt)Dont do in your self i you dont know the parts or high voltage crt,its dangerous
but if are technician no problem the problem of your tv is depend on the following
1, High B+
2. Filter capacitor near power supply
3. dirt near neck
4. socket picture tube faulty
5. picture tube
6, checked the correct voltage
Posted on Jul 12, 2012
  • 585 Answers
If the sparks fly from the area of where the fat red wire attaches, it could just be that the insulator has broken down allowing the high voltage to arc to the nearest part. It may be possible to replace the insulator, it's just a piece of molded silicone rubber, and there's one in every CRT type TV and computer monitor. Be careful though, as you can see, there's high voltage at that point. Allow it to dissipate for at least 30 minutes before tackling the project, and even then there's enough left to cause a big surprise. Use a wire lead and thin screwdriver to discharge remaining charge(slide screwdriver under the rubber) to the metal brackets that hold the tubes to be safe. Be sure your wire is secure on the bracker and screwdriver!
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
The tv made a "pop" sound and turned off, now when I turn on the tv the screen is black and there is a buzzing sound, Is the a bulb issue?
Yes Lamp is Bad and Buzzing sound is Ballast board spark cap arking. Lamp is a XL-2100U Fox has them for $109.00 other companys want $215.00 for it
1-800-227-5369
Dec 31, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Loud pop from projection TV, then no screen
Ur power board it dead.Replaced capacitors that puff up or pop open.Or replaced the whole board.
Dec 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KP-57XBR10 57" Rear Projection Television Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
