Question about Memorex Paper Shredder
Shredder is very sluggish
The sound of the shredder changed and the action slowed. Does it required oil? If so, where to I oil it?
Here is a cautionary tale. We had a shredder made by Royal. (The PX12D1 crosscut shredder.) It worked fine for about a year. Then after a rigorous shredding session, the blades started to run really slowly. It sounded like the motor was still working though. We examined it for metal debris and found none. After reading some advice here, we decided to clean it out and apply some lubricant. Our intern used a can of air on the blades, and unscrewed the top portion to clean out the dust around the wires. (There was a lot of paper dust in there.) She was very careful not to disturb the wires while cleaning it out. She screwed it back together and used some dry spray lubricant on the gears and blades. This was per the advice on several webpages on this subject. We plugged the shredder in and ran a shredding test. Again, the blades kept moving slowly and wouldn't shred. And then "BOOM!" the darn thing exploded. Our intern said that she saw a bright yellow light appear around the blades just before the explosion. We suspect that the lubricant caught fire. Our intern was shaken up, but fine. Fortunately she was standing up and looking down at the shredder when it happened and the paper waste try absorbed most of the force. But the room was full of gassy smoke for a while and we were all shaken by the experience.
Lessons learned: Shredders aren't that expensive, so tinkering around with one isn't worth our time or risk. When we run into a "slow" or malfunctioning shredder in the future, we will simply toss it and buy a new one. We didn't do anything weird to the shredder, all we did was use a can of air and lubricant. We feel very lucky that our poor intern wasn't injured during this incident.
Posted on Aug 06, 2013
    President:
  • 1,185 Answers
Yes they require lubrication
You can buy shredder oil from lots of office equipment suppliers
To see if it helps spray some WD40 (using the plastic extender) into either side of the opening where you normally put the paper.
Switch the machine on to run continually and give the blades another good spray
This should loosed up any dust which has gathered
If the machine picks up its pace then go buy some real shredder oil and use it before every operation
Do not go mad with the amount you apply but dont skimp
Posted on May 31, 2009
  • Tom
    Tom May 31, 2009
How effective is transmission oil /gear box oil to an automatic vehicle if it has not been changed for a long time. What can it cause on the vehicle? (in my case a Toyota Noah Auto)
all transmission oil break down from the heat and stresses generated by the transmission operation
the additives in the oil are eventually all neutralized and the residues so formed create a gum that slows down the change actions and the ability of the servos and solenoids to operate correctly
bands and clutch pack tend to slip or not release quickly on ratio changes
indications that an oil change is require include slow to change up or down
staying in a ration when coming to a stop resulting in sudden gear shift or shudder
not change at the required speed/engine rpms range
requiring the foot to be lifted to effect a change of ratios
many manufactures recommend a change at around 60,000 klms but other manufacturers like GM say it is not necessary
if you have a dipstick, pull it out and if the oil is not cherry red or a really light tan color ( depending on the atf specified oil) have it changed professionally
Jan 13, 2017 | Toyota Cars & Trucks
Oil fill level for a cyclo action chipper shredder
engine?
if no dip stick then it is usaly to top of fill hole at base Checking and Changing Oil
May 19, 2015 | Heavy Machinery
Black and decker shredder will only go in reverse, when you try forward it makes a loud sounding noise and will not take the paper
Shredders require maintenance. They have moving parts that make lots of dust.
Check your user manual. Does it require oil or special oiled sheets? If so, you might be overdue for this maintenance. Also, check the frequency of how often you are supposed to oil/add oiled sheets to it.
If it won't accept paper in the forward position, then you might be out of luck with trying to run oiled sheets thought it. If it's still under warranty, see if they can repair it for you.
Mar 02, 2015 | Black and Decker USA Black & Decker -...
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
Have a tech solutions 4500. how do you lubricate it?
  1. Cross cut shredders require more frequent oiling versus the straight strip shredders. The more paper and use it gets the more oil it requires. A good rule of thumb is to oil the machine each time you change the bag.
  2. Use only shredder oil designed for the specific brand of paper shredder you have. Manufacturers design paper shredder oils to be heat tolerant for the cylinders and blades, and they calibrate them specifically for their machines.
  3. Spray, squirt or run a bead of oil across the blade opening. It shouldn't take more than a second or two to reach from one end to the other. Any more than that may result in too much oil applied. Quicker than that means there isn't enough oil to adequately lubricate the machine.
  4. Turn the paper shredder to "Manual" and run the gears in reverse for a few seconds, then turn the shredder on "Forward" or "Standard" mode. This ensures that you distribute the oil throughout the machine, and going in reverse first forces some of the dripping oil back up, and then the forward moving blades push it back through the gears.
  5. Oil a sheet of paper rather than the machine. Don't just run a bead of oil across the bottom of the sheet because the paper soaks up the oil and the oil may not reach all of the necessary parts. Instead, spray the whole sheet, or run a zigzag line across the paper and immediately send it through the shredder to oil it.
Jan 28, 2011 | Tech Solution TS-4500 Shredder
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
When we put paper in our shredder, even just 1 sheet, it sounds real sluggish like it's losing power, then it almost shuts off and the trouble light comes. It's plugged in. Is there a fuse or something...
Have you ever oiled the machine.?????
Cross cut shredders need to be lubricated due to the amounts of small paper and dust generated.
Get some "shredder oil" run the machine in reverse and pour some of the oil onto the cutting blades...then when you shred paper put some oil onto a sheet of paper prior to putting it in the shredder. How often do you oil it??? depends how much shredding you do.
Nov 20, 2010 | Royal 1280MX Shredder
Running sluggish and will only shred about 5 pages at a tiem model #OM 96146 Office max
Favorite with shredders... put some shredder oil on a sheet of paper and shred the page ... you may have to do this a few times if you have never oiled inside the cutting blades.
Sep 27, 2010 | OfficeMax 0M96431 Shredder
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
181 people viewed this question
Top Memorex Office Equipment & Supplies Experts
Steve
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
