Question about Panasonic Televison & Video
My tv turns off immediately after being turned on
The tv shuts off after a few seconds of turning it on, I do get to see an image coming up for the few seconds. When it turns off the red power light blinks three times. The tv is a panasonic cinema vision hdtv model number pt56wx53g
Slinteriors
  • 8617 Answers
SOURCE: Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Feb 15, 2009
  • 1779 Answers
SOURCE: panasonic cinema vision model pt47wxc43g has
Sounds like Convergence Ic's are defective. The best advice would be to contact a Svc. Co.
Posted on Feb 26, 2009
SD Tech
  • 14553 Answers
SOURCE: how do you calibrate a rearprojection panasonic
OK, I know this set very well--if convergence in the customer menu is skewed and red or blue will not adjust in some direction, you have a convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay for about 20 dollars if you can do it yourself or know someone who can do it for you--you can save the set and a lot of money......most shops get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
Posted on Nov 20, 2009
Testimonial: "Super fast responder, very helpful!"
ASE TECH
  • 57 Answers
SOURCE: We have blue lines or arches on the bottom and top
if you are handy with screw driver i suggest you remove all cd,dvd or anything you got on top of the unit and remove the back panel from this tv after you unplug the unit of course .first thing you want to do is clean your lenses most time dirt ,bugs,etc and other materials get logged on the lenses also make sure you dont spray directly any cleaning product on the lens make sure you spray a rag or some sort of cleaning towel.
after you finished doing this clean the front panel as well were screen is also clean the silver board thats in there as well.after you finish all of this replace all of the screws and boards back on and give it little while to dry off .turn it on see if u still have the lines if you do then your problem lies in the lenses they might be cracked.
if there not you might have bad electrode or power diode going bad.
Posted on Jan 09, 2010
Slinteriors
  • 8617 Answers
SOURCE: my panasonic cinema vision hdtv model # pt-47wx49
Does the power indicator blink? If so how many times does it blink?
Posted on Jul 29, 2010
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
When I turn my television on it auto turn off after a few seconds. The light starts to blink when I first turn the tv on and then the Tv just shuts off on its own.
Hello Sir, hi, you have power supply problems, this is caused by a bad part on the main board or on the power supply board to overload, when overload happens, the power supply immediately shuts down to prevent further damage. my first advice is call your dealer for proper service.
Dec 07, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
When I turn on my television, the picture is bright white and it is hard to make out any figures on the screen for a few seconds, then the TV shuts off itself, the little red light will go off and it will...
HI, thank you for visit fixya.
Do you have two possibles solutions:
1.--Vertical IC and capacitors need be replace.
2..-- Convergence IC's is defective, need be replace.
Disconnect convergence plugs ( wires go to yoke) and turn the tv, see if any changes happenings.
Any question, I will be here, Thank you
Nov 11, 2009 | Toshiba 57H82 57" Rear Projection...
TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Sep 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Televison & Video Logo
274 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
