I want a power supply adaptor for it
Dear sir ihave a infocus smartview model.3600 the power supply adapter is not working so i want a new one where can iget it i dont know the power rating
  • 400 Answers
You can purchase it from WWW.EBAY.COM and power rating can be know from the device back or from the old adapter..
Posted on May 31, 2009
Need Okaya power adaptor for Protron TV Power Adaptor Model 090-02180-13Bob
Good Day Bob!
This one costs $117.99 and you can purchase it online from the link below:
http://www.powerpayless.com/ac-adapter-replace-yhi-090-02180-13-power-supply-for-protron-sova-a.html
It is an AC adapter replace YHi 090-02180-13 power supply for Protron, Sova, A
Please rate my answer.
Thank you for asking Fixya
Jul 13, 2011 | Protron Televison & Video
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Monitor wont come on.green lite on the switching adaptor is off.Is the adaptor bad or monitor bad? How do I get a new adaptor?Model # WDS048120
The lamp on the power supply adapter should be on the minute it is plugged onto the AC outlet without the DC plug connected to the monitor, if it is not on then the AC adapter is bad, you can check the DC voltage with a digital meter. Post back so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | X2Gen MG19MY 19" LCD Monitor
Need power supply for 32'' Protron PLTV-32 - AC adaptor Model:090-02180-13
I can repair the bad YHI 090-02180-I3 adapter for $60 plus shipping. Let me know if you still have it. dave@thola.com
Sep 04, 2009 | Protron PLTV-32 Television
Brand new dell inspiron 1545 says it is the wrong charger but it is the wright one battery will not charge but will run from ac adaptor
take another adapter , same type you have it and prove is working or not?
if yes meaning that output current in your adapter is wrong it is defektive , and change, if even second adapter is making same thing try to get another model adpter that is close in power and curent ratin with yours or same, if isnt working this too try another batery because maybe is finished, if even new batery dont work with your adapter or a second adapter you have to service your laptop inside in electric circuit entering is blown out.
Apr 04, 2009 | Dell Dimension 8400 power supply ** FREE...
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
Aug 27, 2008 | Compaq Presario R3000 Notebook
Avion 32" LCD HD TV AC Adapter 090-02180-I3 Problem
I had success geting a comparable a c adaptor at this company.
West Bee Trading
1790 Almond Way
Morgan Hill, Ca 95037 Their E-MAIL is:huweibiao@hotmail.com
I received the adaptor in four days and the TV works fine. It cost $130.00.
My TV is an Avion 32" flat panel
Jul 23, 2008 | Protron PLTV-32 Television
NEED A AC POWER ADAPTER
Had same problem. Found brand new power supply that is original part from website below:
http://www.encompassparts.com/products/?PWW302-AD13D-03
It was about $100 w/ shipping. Took about 4 days to receive. TV works again!!
May 28, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Compaq Ipaq 3600 (Why won't it turn on without the adapter?)
Man this sucks I've been trying to make it work and it just doesn't seem to be working. I don't get it, why does it work on power supply but not on its own away from the supply. Help.
Sep 12, 2005 | Compaq iPAQ H3650 Pocket PC
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
