Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not come on
You pull the knob and it sounds like they are running, but they are not. Belts look good and we cleaned around them.
Are any pulleys turning when you engage? Is you tensioning spring or arm either bent or not attached properly.
Posted on Jun 01, 2009
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Just what does an electric clutch do
The electric clutch on a lawn tractor or zero-turn mower turns on the mower deck. Instead of a lever that you pull to start the blades, you pull a red knob.
The advantage of an electric clutch is the belts stay tensioned all the time and the belts should last longer.
Jun 17, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Some wire wound up around the blades on my riding tractor. I removed all the wire and now when I lower the blades, the mower will not engageshear pin
when the wire wound around the blades, did it move the drive belts? Check the belts on your cutting deck. If the belts are good and are still in the proper pulleys, then it could be the shear pin on the shaft coming from the engine.
May 19, 2014 | Craftsman Garden
Bladesdoturnwhenengaged
your belt has most likely jumped out of it's intended route, or has broken, check with engine NOT running keys out switch off, pull engage knob and try to manually move blades if they move while knob is engaged, belt is broken or off track
Mar 21, 2014 | Husqvarna Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I have a john deere gt242 mower, when i pull the pto knob to turn blades on they wont turn on. What could be the problem
Could be debris in or around the assembly,check under the fenders too.Check the tension on the belts.Good luck and happy mowing.
May 11, 2011 | John Deere Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
83 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
