Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Strong signal but no connectivity
I have a D-Link 524 wireless router and am having connectivity issues.  My signal is always strong and I always have four green bars.  Only able to access the internet if I am with 15 feet of the access point.  Once I move more then 15 feet from the access point I lose connectivity even though the signal is strong.  I have updated the firware and am unsure how to solve this problem.
Any suggestions...
  • JamiePheno Nov 10, 2007
    I have a similar problem to Eddies. My computer shows Dlink is transmitting very strong, but no internet connection. I know my computer is ok because I can connect to other wi-fi networks. I shut everything down 2X and started over. Unfortunately I bought the 624 in China where I am working for a while and the instructions are in Chinese.
    Scholar:
  • 193 Answers
Ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Posted on Oct 23, 2007
SOURCE:
Low connectivity for d link 524 airplus g
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
May 25, 2012 | D-Link AirPlus G DI-524 Wireless Router -...
Weak signal
Where are you measuring the speed:
* transferring files from one computer on your network
to another computer on your network?
* using a "speed-test" web-site (http://speedtest.shaw.ca) that reports the speed?
What level of service are you paying your ISP for? "Lite"? "High-Speed"? "Extreme" ? "Nitro" ?
The "bottleneck" could be between your ISP and your router,
not between your router and your computer.
Dec 13, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a DI-524 Air Plus G Router and would like to send signal to a location 350 feet away in another building. Is this possible? Currently I can receive a very weak signal, but not strong enough to...
not without a repeater or maybe outside antenna. then the signal would probally be too low. you are working too far for wirless and thru building walls.
Jul 07, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in http://192.168.0.1 in the address box
If this doesn't work try http://192.168.1.1
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Feb 19, 2009 | D-Link AirPlus DI-524 Wireless Router
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link 524 router not working
Double check that you are connected to your router and not a neighbors router.
Mar 29, 2008 | D-Link AirPlus DI-524 Wireless Router
Coverage and speed have reduced
You can find the complete solution on the web link given below.
Please click on the web link given below and check for the exact issue and solution to get the issue fixed.
http://support.dlink.com/supportfaq/
I hope this will help you further with the router information and maintainence.
Have a great day!
Feb 29, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
109 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
