Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Picture is distorted from center on my 65
When turning on my Sony big screen tv one morning, I immediately noticed that the picture was very distorted. I can see blue shadows or ghosts to the left of images on the screen. Using the manual, I tried to adjust the convergence. Prior to adjusting I noticed that there was a blue shadow to the left of all the white "+" signs on the screen. In the center of the screen the shadow was just barely to the left of the "+" sign. Moving away from the center to the right and the left sides of the screen, the blue shadows move farther and farther to the left of the "+" sign. Is this something that should be fixable by adjusting the convergence? I have some soldering experience - is this something that can be fixed by a novice, or would I be better off trying to buy the part (or board) in a local tv parts store? By the way, I tried using the flash focus to adjust the picture colors but it didn't work? My problem is similar except that on mine only the red color seems to be pulled down on the corners only. the center of the picture is as sharp as ever. anyone have any advice?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please mention exact model number of your Sony TV to look for proper solution of red convergence problem.
  • 80 Answers
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
Posted on Jun 01, 2009
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
Posted on May 21, 2009
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with Mitsubishi WS-65315 65 in picture simply off the screen. too big for the screen so u cant see 15% of all picture. on any input source like cable, dvd, components.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
The picture is distorted. It appears as the picture is being drawn to the center of the screen.
This is a convergence problem. This can be either bad solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These are large black ICs attached to a heatsink.These should be marked STKxxx.
Keep me posted.
Dan
Sep 30, 2008 | Sony KP-65WS510 65" Rear Projection...
Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
Sep 09, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Rear projection tv picture distorted
The STK convergency ICs seems to be the problem with this TV.
Here is a picture as well with the same symptoms.
Feb 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Toshiba 43H70 Picture Problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 43H70 43" Rear Projection...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
239 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
