Question about Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966
Troy Bilt in Hell String Trimmer TB465SS Running Problem
Troy Bilt in hell TB465SS String Trimmer problem. When starting, although the manual says the cutting mechanism should not turn, ours does. Adjusted the idle to no avail. Larger issue...upon starting, will not accelerate. The slightest tug of the trigger causes a stall. Tore the carb apart, put new gaskets and washers in, carb cleaner, bla bla bla; tore the exhaust off, cleaned the screen. Still nothing. Checked air filter and it was clean. Used this new trimmer a total of 3 hours. Don't quite understand the genius behind the no string feed method (feels like I got punked). I want to take this thing out back and shoot a hole in it. Can someone save this thing from its fate?
  • 2 more comments
  • lyons8221 Jun 01, 2009
    Hi Panilling - Correct, it does not have a clutch; however the crazy manual says it should not spin when idling. Also correct but thanks for asking, it is a 4-cycle and the gas and oil go in two different tanks. Adjusted the carb, but no improvement. I really hate this thing, but I know it can work, I just have to look at it the right way.
  • panilling9
    panilling9 May 11, 2010
    according to you model #you gave your 4-cycle trimmer does not have a clutch? thats why your trimmer head spins when you pull the rope? if its a 4 cycle you know that gas and oil go in a seperate area correct? and not a oil mixture like a 2 cycle?
    just clarifiying that you are aware of this.
    sounds like you need a carbruetor adjustment,but it may have plasic caps on the adjustments that you cannot access
    but if they dont you need to locate the L on the carb. and turn it out 1/8th turn and see if that helps your issue.
  • john Oct 09, 2012
    same exact problem on my TB465SS trimmer. it has caused me much trouble and i cant fix it. it has never reved up even when it was brand new so i dont ttink cleaning anything will do it. is there a way to adjust the air intake besides the choke? becasue adjusting the choke is not a permanent fix.
  • Cecil Berleth Oct 19, 2012
    How do you adjust carburator, it runs hit trottle dies - where is adjustment screw located and where can I get the tool to do this
  • 1,040 Answers
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 08, 2009
    Did this solution solve the problem?
    Jim
  • john Oct 09, 2012
    no ********.
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
TB465SS trimmer won't rev up
change spark plug and check the gap between points
Jul 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt trimmer TB 490 BC
Turn the bump knob clockwise to loosen on my tb490bc.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a TB465ss weed eater. It was running fine last time I used it. Now when I pull the rope it stops half way. It does not turn the motor and I cannot start it. Anyone have an idea what is wrong
Sounds like you have fuel leaked into the cylinder. Remove the spark plug, empty it out, pull the rope a few times to force out the excess fuel, dry the plug off and put it back in. Don't put the choke on, open the throttle all the way up, and she should start. Remember, liquid doesn't compress, and sometimes changes in temperature or atmospheric pressure can push fuel through the system and into the cylinder.
Mar 24, 2010 | Troy -Bilt String Trimmer/Blower...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966 Logo
1,309 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
