Question about Sony Computers & Internet
Small screen on my laptop
Need agp driver install
    Problem Solver:
  • 5 Answers
Try Uniblue driver scanner.
http://www.liutilities.com/
serial:
http://forum.djawir.com/pc-software-108/serial-uniblue-15820/ [I think]
Posted on Jun 01, 2009
PNY VCG84512SPEB GeForce 8400GS (ASUS K8U-X)
I have no idea why you would go from an agp to a pci. Agp has like 8x the banwidth of pci.I'll assume the agp slot went bad. If you can get into bios before you lose the display,change the display from agp to "init pci first",save & re-boot. See if that works,then when in windows install the drivers right away. If that doesn't work, during boot at the splash screen, press f8 & select "safe mode" with networking. This should let you get into windows so you can remove the old agp drivers,then re-boot into safe mode again & install the new drivers. Then re-boot normal & you should be ok. If not,that board has a big problem.
May 14, 2010 | ASUS K8U-X Motherboard
Enable AGP 4x
you don't need to reinstall or format c:\ ..all you need uninstall al the drivers and install the correct driver of your VGA add on card.
Jan 18, 2008 | ASUS VIA 694XDP Dual Processor Chipset...
PHILIPS FREEVENTS X60 LAPTOP
The X60 is actually the "Twinhead Stylebook 10D", under the brand of "Philips". Everything you need can be found here: "http://www.twinhead.com.tw/site2005/download.aspx "
I had exactly the same problem after a hard disc format, and I was searching for many hours for the solution. After I installed these drivers, ALL the devices are working perfectly!
Sep 27, 2009 | Computers & Internet
What graphics cards can I use with a KW7 motherboard
Do you have the Motherboard Manual for your Abit KW7? If not here is Abit Support, and the Manuals download page,
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&fSEARCHTEXT=KW7
(Just copy then paste it into your address bar. Press the Enter key)
The top file listed is what you want, not the KW7-G listed below it. Click on the blue icon. (Monitor with an arrow coming out of it)
This is a Zip file. A small window will come up, where you choose to->
Open with, or Save file. Click on the circle to the left of Save file.
Now go down and click on OK.
If you do not have your downloads set to go to your My Documents folder, (Start>My Documents), this zip file will go to your desktop screen. In either place double-click on the file name. In the next window go up to the top left, and click on -> Extract all files. Click on Next, then Next, then Finish. Now double-click on the PDF file icon.
Page 5 tells you it's an AGP slot for a graphics card. Page 21 tells you that it will support AGP graphics cards UP TO AGP 8X.
(Either an AGP 4X, or an AGP 8X. You do not want an AGP 4X graphics card! You want an AGP 8X graphics card. Uses 0.8 volts. {AGP 3.0 version)
You should also download and install the VIA 4 in 1 Drivers, if it hasn't been installed already, (Your motherboard has the VIA KT880 chipset)
http://www.viaarena.com/displaydrivers.aspx?PageID=1&OSID=1&CatID=1070
(Read about the VIA 4 in 1 drivers on Page 51 in the Motherboard Manual)
Also here is a list of drivers available for your KW7 motherboard, from Abit Support should you ever need them,
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=KW7
Now if you are asking specifically what AGP graphics card should you buy, and install, I can give you an example. Only based on what I think. Use your own judgment.
1.Sapphire Radeon HD 3850, with 512MB of GDDR3 graphics ram. It's an AGP 8X graphics card. Only requires a 450 Watt power supply with a 30Amp 12 volt power rail. Does need 2X4 power cable from power supply.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
Aug 15, 2009 | Abit KW7 Motherboard
Startup problem
Try to plug it with external monitor and check again is it working with external monitor , then check display adopter driver of your laptop , re-install the VGA driver,
If this thing find use full kindly send comments
Mar 26, 2009 | Dell Inspiron 5160 32MB DDR AGP Graphic...
Problem with k7s41GX
try to check your RAM.. maybe your ram is LOSE connection or physically damaged.
Feb 04, 2009 | Asrock K7S41GX Motherboard
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Need nvidia mx400 64m 64bit ddr 4x agp driver
i lost my the driver cd for my nvidia mx400 64mb 64bit ddr 4x agp card. i dont have an internet connection on the pc in which the agp is installed. can u send me or help me to find the specific driver for the model of my agp card.
Nov 16, 2008 | Nvidia GeForce2 MX200 64MB 4x AGP Graphic...
AGP installation problems
If you do see the BIOS post but the screen turns black when your OS is loading, then the AGP-card should be OK. HOWEVER, you do need to uninstall your MB-video drivers before installing a new GPU.
Jul 06, 2008 | ASUS K8V-MX Motherboard
Driver is not working
strange... even WinXP has got the drivers for that ATI AGP card.
Apr 07, 2008 | ATI ALL-IN-WONDER 9600, (128 MB) AGP...
Computers & Internet Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
