Question about Microsoft Xbox 360 Console
Xbox 360 error code 0002
Hello i have replaced my clamps all seemed to go really well but now i have got the error code 0002 network error. does this mean that the internet connection socket has unsoldered or is it something more than this. thank you i have the same error but my power brick stays yellow and wont power up before i fixed the x clamps it would power up but would not heat for 20 mins would cut off before then now i still get 3 rlod baut no power help me please
    Genius:
  • 1,234 Answers
Hi sir
0002 Network Interface problem
Posted on Aug 26, 2010
I currently have the 0002 error code on my xbox 360... I have tried replacing everything. How can I fix this?
replace the C8U1 fuse... The "C"
it's around at the U8U1 on the bottom of the main board. Coordinate
"8U". If you try to remove this capacitor, the XBOX release for you
a nice code "0002". ;)
Thanks
www.1RepairStop.com
Sep 18, 2011 | Microsoft Xbox 360 Console
How do I fix my xbox 360 from error code 0002?
1) Scan the mainboard and make sure that there is nothing that might short something out, like metal chipping, components, that moved out of place while reflowing, etc. - Especially in the CPU area
3) Replace MOSFETs and regulators that are known to cause it if they were blown
4) Check if the standby voltages are existent, if they are not at a certain area replace the parts in the area which are likely to be defective.
5) Reflow the CPU
6) X-Clamp replacement
If you are not able to do these or do not want to do these, you must send it back to microsoft for them to repair.
Jul 03, 2011 | Microsoft Video Game Consoles & Games
The console shows that I am connected to the wireless internet in my home, I am now getting error reports of W 0000-0002,X C000-4003, Y 0000-0000, Z 0000-0000 and ID FFFF-FFFF
With this type or error code that you;re receiving on your XBOX the next thing to do here to correct the issue is to reset the network settings of it and then after that do reconnect your XBOX to the network and its will be fine.
Nov 23, 2010 | Microsoft Xbox 360 Elite Console
Error Code 0020
First, my xbox would have one red light and E 74. Then when I opened it up and booted it I got three red lights and 0020. I took out the motherboard, replaced the heatsink compound and did the x-clamp fix, but I couldn't get nylon washers in the right size so i just used no washers at all. Varying the tightness of various x-clamp bolts gave me 0020, 0003, 0002, 0001, or it would boot up to the black screen and I'd get E 74 again. Other times the xbox would almost immediately overheat. Most of the time I would get 0020, though. At that point, I gave up and I just tightened up the bolts replacing the x-clamp a certain way (nothing seemed special about it) and put the motherboard back in the case without testing it. I screwed everything back together, and since the heads of the bolts were thicker than they should have been, the motherboard didn't really sit flat in the metal cage. But i just screwed the motherboard back into the cage not to tight with the 9 small silver screws, which I would imagine put some stress on the mobo. Then I pu the rest of the case on and the 6 long screws, and once I had snapped everything back together I tried booting it up. To my great surprise it booted up fine! I played some halo 3 and it has booted up fine every time (3 times) since then
Many people have got this error You need to replace the xclamp and make sure there's extra pressure (less than half a turn) on the front right corner of the GPU. You can read more about xclamp replacement here.
its not an issue with ur HDD so no worries....
regards iversh
a very helpful rating is appreciated for answering ur query
Sep 17, 2009 | Microsoft Xbox 360 Console
Error code 0002
It's a network interface connection.
Jul 01, 2009 | Microsoft Xbox 360 Console
Xbox live 'internet' connection failing.
This will be why...
you need to wire the xbox to the router.
if you wire it to your laptop then its just a network connection between the laptop and the xbox.
Im not to sure but if you keep the same setup you may be able to share the internet connection.
Apr 06, 2009 | Microsoft Xbox 360™ Premium White Console
Xbox 360 code 0002
Go here you will fix your Xbox in 2 hours dont mess around you may do more damage http://xbox360repaircenter.info They help me out a lot
Oct 22, 2008 | Microsoft Xbox 360 Console
So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection. Error code "0002" is a Network Interface problem. Since you have already replaced the clamps (I'm assuming your talking about the "X" clamps) there is only one other thing that might bring it back to life is re-heating the chips, sounds odd but has worked. Use a heat gun and slowly heat up the chip's, be careful not to overheat them. Try turning it on and see if anything changes, do this every so often until you get the results you need. REMEMBER< DO NOT OVERHEAT OR MELT THEM, USE CAUTION ANS COMMON SENSE. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
If this doesn't work you may have to get a new one.
Jan 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 0020 error code
here is a site i found that shows detailed fixes for this error with your 360's - here it is
Jan 05, 2008 | Microsoft Xbox 360 Console
check this link http://xbox-experts.com/e/errorcode.php?s=0002
you should find your answer there, seems that there is a small possibility that is related to the Ethernet chip...not entirely the solution but it will give a prety good idea where to start!!
Nov 04, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
340 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
