Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
1 month old electrolux FL IQ cuts off and won't restart
We have an Electrolux IQ and it has been working great until today. The washer will work but at some point during the wash it stops completely almost like it needs a reboot. It won't restart and I can't get the door open because it is acting like it doesn't have power, but the voltage is fine. We have cleared the hose twice and the machine started working again. This last time we cleared the hose it still won't restart and as an added benefit, I can't get into the drum because the washer won't unlock the door. Any thoughts?
    President:
  • 1,185 Answers
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
Posted on May 31, 2009
Electrolux IQ washer dispenser drawer does not lock in place
Suggestion: There could be a plastic lever which is used to take the drawer out to clean, inbuilt in drawer. Take the drawer out to re-fit.
Mar 10, 2013 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Apr 12, 2010 | Electrolux EIFLW55HIW Front Load Washer...
New Electrolux FL washer - will not fill with water
There are three main possibilities here. Firstly there may be a blockage that is stopping the water from flowing. Secondly there may be an item stuck in the pump chamber. Lastly the pump itself may be seized up. On machines that have their waste pipe connected under the kitchen sink it is always worth checking that the plumbing is not blocked with fat or lint at this junction. Check for kinking of the waste hose, this may of course release itself if you pull the machine forward. As for blockages and obstructions inside the machine itself it would be difficult to give any real guidance as there are so many models. If the pump is seized or defective the solution is nearly always the replacement of the whole pump.
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
604 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
