Question about InFocus ScreenPlay 61" Rear Projection HDTV
Screen going off and on
When I turn the tv on, it comes on then turns itself off about 10-15 times, then it stays on for a while.  what could the problem be.  I have an InFocus Screenplay, 61 inch.
I Had the same problem. I removed the lamp and found the wires for the cooling fan had got hot and the protective cover missing in spots bare wires were close enough to short Itaped them up reinstalled the lamp and it is now working. Don't know how long it will last so I'm ordering a new lamp assembly.Just in case,
Posted on Nov 20, 2007
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
Apr 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
The screen on my plasma tv keeps turning itself off....
it seams that your tv is high heated or it is needed to change some of the tranzistors... as it seams the damage isnt realy bad..but it need an "experts hand" to be fixed
Nov 29, 2007 | Televison & Video
InFocus ScreenPlay 61" Rear Projection HDTV Logo
116 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
