Dead with a high pitch sound while plugged in.
My Sanyo t.v. model number DS25320 just stopped working. The screen does not come on, but there is a high pitch sound that comes from the T.V. while it is plugged in. What suggestion do you have?
silly girl
  • 513 Answers
SOURCE: Sanyo DS31520 went dead
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Squealing noise is from the power supply teling you that there is an overload condiction. The overload is shifting the operational frequency of the power supply into upper audio hearing range. Check the diodes and caps in the supply circuit and the active components in the deflection circuit. also resolder the LOPT, h-output, h-driver, and h-driver transformer. Good luck
Posted on Jun 21, 2006
jomaru
  • 337 Answers
SOURCE: No picture only a high pitch sound
Yes,it can be repaired,sometimes for no reason components fail and they need to be replaced,if you are familiar with tv service you can check the horizontal output transistor,it might have gone bad(shorted out)and is all is going to take to get the set back running,sometimes the output trasformer damages the transistor and both have to be replaced,first just change the transistor and if it blows up again then replace the transformer,if you are not too familiar with servicing a tv be safe and call for assistance from a servicer,if you take the set to them it should be expensive.Let Us know how it goes or if you need more information.
Posted on Nov 08, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Posted on Nov 28, 2006
  • 3 Answers
SOURCE: RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Posted on Oct 20, 2007
SOURCE: My Sanyo TV
this is a good spot http://www.mrremotecontrols.com/
Posted on Jul 17, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
High pitched ringing sound from my tv
It most likely is coming (based on model number listed here) from the high voltage transformer---ways to silence that up to and including replacing that part.
Jun 16, 2012 | RCA HD52W59 HDTV Projection Television
Have sanyo 25in color tv with no manual and want to hook up a wiisystem it is currently hooked up to dishtv model ds25320 and family group vc8b
Connect the yellow rca plug from the wii to yellow jack on the tv marked AV1 and the red and white rca jacks from the wii to red and white rca jacks of the AV1 hookup. Simple.
Aug 30, 2011 | Sanyo Televison & Video
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
Nov 08, 2006 | Sanyo DS31520 31" TV
No picture,no sound,blank
This set is very popular for the capacitors to dry upa and go bad in the main SMPS as well as the switching power supply. If you have no know how on how to test capacitors or solid state electronics please take the set into a repair shop for an estimate
Jul 28, 2006 | Sanyo AVM-3659S 36" TV
Jun 19, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
