Stereo keeps switching off
My technics stereo plays for a while then it switches itself off can you please help.
SOURCE: system keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
Posted on Sep 08, 2007
  • 4 Answers
SOURCE: technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Posted on Nov 13, 2007
  • 4234 Answers
SOURCE: My Technics SL-DV290 stereo has
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Posted on Apr 02, 2008
SOURCE: My N73 keeps switching itself off.
This may work for you as it did for me. You need to upgrade the software.
Posted on Apr 11, 2008
marsrover
  • 682 Answers
SOURCE: technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Posted on Jul 05, 2009
Cannot play my ipod through my technics amp
You would need a mini jack to stereo rca wire. Insert the mini jack to your Ipod's headphones, then plug the stereo rca to your amp inputs. If it's a receiver, plug into any of the inputs (aux, tape etc) except "phono or turntable", then switch to respected input on the receiver. Be sure all volumes on both units are down during this process, then gradually turn up both volume to normal level.
Apr 04, 2014 | Technics SA-EX500 Receiver
The cassette deck in my '95 BMW 325i now just flips from side 1 to side 2, without actually playing. Everything else with the stereo still works fine. Might this be a problem that a non-profession
The unit has to come out of the car and taken to a auto Stereo repair shop. I would guess without seeing it that there is a loose belt that is causing a detection of the deck not turning the reel the detector is on and that tells the electronics the tape has stopped and if there is no drive in the other direction it does the same thing. If a capstan belt breaks there is no drive in either direction. The belt may not be hard to replace but you need to know the routing and the size then just order from MAT Electronics or MCM Electronics and put it in. I also think the Head and Pinch Rollers are going to need a real good cleaning. Use Naphtha for that. I serviced car stereos back in the 80 and 90 not so much anymore. If you can do it depends on your technical ability.
Jan 20, 2013 | Audio Players & Recorders
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
When i turn on my playstion 3 console it switches back off and shows me a flashing red light and the if i keep trying for about 1 hour it turns on but then when i turn on the game to play it switches...
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot Click Here
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Stereo keeps switching on by itself
Is this a factory stereo.......what barnd is it, and when is it turning itself on
Sep 20, 2010 | CIBA Vision Ford Focus 2007 Stereo/radio...
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
Technics amplifier switches off
Jul 05, 2009 | Audio Players & Recorders
I don't now what settings to use on my technics stereo system it has 5.1 surround sound. My prob is I don't now what levals to set the speakers at for best results in the book it says I should hear bullets...
switch off pro logic/switch on supper suround/press button twice it will say MOVE:/
switch on Supper suround EQ then Vertual Rear suround then Multi Rear suround then Seat Position.they should be lit GREEN exsept Vertual Rear & center focus.
Seat Position should flash when it does move the curser in the middle of the jog dial.......... i.e UP:DOWN :LEFT :RIGHT .let go & it will set itself. then switch on the Supper s woofer on the amp to MID.
I THINK L.O.L
Jun 10, 2009 | Technics SC-DV290 System
you probly have a bad wire or wires arching
May 19, 2009 | Sony CDX-M630 CD Player
Switching on by itself
Hi...
Try covering the little red window that has the wireless remote receiver behind it. See what happens.If the problem quits,your stereo is picking up some other IR source in the room.
Also,shoot some WD40 into the cutout around the power switch
( WITH THE POWER UNPLUGGED) push the switch on/off several times then plug the AC back in.
Jan 07, 2009 | Technics SCEH790 CD Shelf System
43 people viewed this question
 Grubhead
Grubhead
