Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-32S2000 flashing stand by.
My Sony LCD TV is flashing "Standby" and will not turn on. What can I do?
  • 320 Answers
SOURCE: Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
  • 67 Answers
SOURCE: Have a new Sony Bravia
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Posted on Jun 24, 2009
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
  • 11361 Answers
SOURCE: my Sony Bravia LCD TV KDL-V40XBR1 doesn't turn on
You need to do some troubleshooting before buying any parts.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 24, 2010
0 characters
1 Points
Tv goes to standby all the time
saya lupa password pokercc saya boss,,tks
Nov 21, 2013 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
B+ Over Voltage Protection problem Sony Bravia KDL 32S2000
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia KDL 32S2030 is showing a flashing led standby (4 flashes/2 secs/4 flashes. I can unplug the mains cable, leave it for a few minutes and when I pug it back in it will re-set to the green...
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
Oct 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv turns on then turns off to stand by blinking
the time or the limit of the program is not applicable because it is not touched.
Apr 05, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony Bravia KDL-32s2000 down from wall mount and can't find stand
Yes, Sony Parts has them available:
The stand is $107.59, and requires four screws to attach to the TV. They're $2.25. (quite the bargain!)
The model number of the stand is X21033652.
Please rate my answer if it solved your problem.
Apr 19, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
134 people viewed this question
Top Sony Flat Panel Televisions Experts
Mando Mojica
Mando Mojica
Brian Sullivan
Brian Sullivan
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
