Question about Kyocera Copystar CS-1820 Black and White Copier
Installed upper & Lower Fuser, Turn Copier on saying paper jam 03
Copystar CS 1820
  • 523 Answers
Its not really a jam, its the cover you have to play with it on order to lock well.
Posted on Jun 14, 2009
E 6000
6000 error. Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on
Nov 12, 2013 | Kyocera Copystar CS-1820 Black and White...
Paper is not being pulled from tray properly
Change your drum unit, it seems the drum is spinning good, let me know where the jams happen! In the fuser unit! in the cassette!
Dec 05, 2011 | Kyocera Copystar CS-1820 Black and White...
I have a Copystar CS-1820 all in one, the paper is getting jammed after it has not been used for a few hours, once it is cleared and re-printed it prints fine, are there rollers or something that needs to...
Usually Pickup Rollers and Cassette rollers needs to be replaced, but if it is jamming in the fuser section then you need to change the fuser unit. it is not hard to replace the part, and if you want i can send you the manual so you just have to follow steps.
Oct 04, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier fade photocopy on one side of the paper?
Try to re install the cartridge? Also make sure the drum unit & developer unit are connected corretly. Odds are one of the two clips that lock the two parts of the drum unit may be broken....
Jul 19, 2011 | Kyocera Copystar CS-1820 Black and White...
I have Kyocera Copier that is trying to print a fax and it keeps coming up JAM 40. How do I fix this?
JAM 40 is a fuser jam. Remove the process unit and make sure there is no paper there. Open the back cover and make sure there is no paper there. Turn the machine off then back on. If you are still geting Jam 40 then you have a bad sensor or similar issue.
Jun 10, 2011 | Kyocera Copystar CS-1820 Black and White...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
277 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
