Question about HP DeskJet 5550 InkJet Printer
Flashing lights I lost my temper when a paper jam occurred and yanked the offending sheet out of the printer from the front. The printer went into a dual flashing light mode (resume light and power light). I pushed each one - no change. I turned the unit off and on - no change. I unplugged it & then turned it back on - no change. The cartridges are located just to left of center and won't move. I promised it not to lose my temper again - no change.Any suggestions???Thanks, Al
  • gentryc Jan 06, 2009
    Ditto! Same Exact Problem! Help!!
  • Anonymous Jan 13, 2009
    exactly the same problem.
    Scholar:
  • 90 Answers
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Posted on Oct 23, 2007
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
Fault 202.02 keeps coming up
Hey there,
The code indicates that you have a paper jam in the system. It may be a small chip or full sheet of paper. It may also be something that fell into the top of the machine. Open front panel and try to locate the offending item. It may be at the fuser outlet or the standard outlet.. Once cleared, the machine should reset itself. just plug in and it should occur automatically.
Oct 03, 2013 | Lexmark W840 Printer
Jammed paper whole sheet of paper is half jammed in machin. I cannot pull it out.
Firmly grip the paper and yank it as hard as possible. If that fails, bring the printer to a repairman.
Jul 18, 2011 | Brother HL-2040 Laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
    The light flashing may mean more things, not just a paper jam. Could mean any of the following:
    - Front cover is open: Close the front cover of the printer.
    - Back cover is open: Close the back cover of the printer.
    - Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
    - No paper fed manual feed slot: Put the paper back in the manual feed slot.
    - Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
    - Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
    - Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
    Thank you for using Fixya!
    Dec 02, 2010 | Brother HL-2040 Laser Printer
    My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
    Hello.
    You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
    Sheet Feeder or Manual Feed Slot: Press the
    paper button to eject any jammed sheets, then open
    the printer cover and remove any paper jammed inside.
    Press the paper button again to clear the error.
    Hope this helps.
    May 31, 2010 | Office Equipment & Supplies
    Error light keeps on flashing blue light at the
    These are your possibilities based on your error.
    Front cover is open
    Fuser cover is open
    Close the fuser cover located behind the back cover of the printer.
    Paper jam
    Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
    Memory full
    The printer memory is full and the printer cannot print full pages of a document. See
    Solving print problems on page 97.
    Print overrun
    A print overrun occurred and the printer cannot print full pages of a document. See
    Jun 14, 2009 | Brother HL-2170W Laser Printer
    My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
    There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
    I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
    Definitely NOT an office friendly machine!
    Aug 20, 2008 | Lexmark E250dn Laser Printer
    Paper jam
    I removed paper from jam, red light will not quit flashing, I turned
    printer off and on again, but it will not print and red light will not
    quit flashing, What can I do?
    May 12, 2008 | Office Equipment & Supplies
    'paper jam' error on canon pixma ip4300
    Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
    Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
    HP DeskJet 5550 InkJet Printer Logo
    455 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
