Question about Garden
Type of oil for pressure washer simoniz s2600
I need to no what type of oil it requires to putt in Simoniz s2600 pressure washer
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Mar 31, 2010 | Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Aug 11, 2009 | Karcher Garden
Manual needed for Simoniz S1800 Pressure Washer
I contacted the Company in US.
Thank you for keeping in touch.
Jun 21, 2009 | Garden
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
I REQ A NEW PUMP MANIFOLD CRACKED HAS ABOUT 5 MINUTES ON IT
Im looking for one too....If i find one i'll let you know....if u find one please also let me konw where i can find it. Thanks
Ravi_w15@hotmail.com
May 10, 2009 | Garden
How to disconnect power hose from s2600 simoniz gas power washer
Just unscrew it like you would a garden hose and pull it out.
Apr 24, 2009 | Honda Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Garden Logo
1,018 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
