Question about Kenmore 64802 Top Freezer Refrigerator
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into defrost mode and water starts to sphew behind the light fixture. Can anyone please help. I have let the refigerator defrost for 2 hours about a month ago. Someone told me this works. Well it did not! What to do! Anyone? Thanks!
  • danwilli2 May 31, 2009
    TO; gdcroft , thanks guy, your suggestions worked. The only thing I would add, is to remove the lower protective cover in the freezer. If your condensate line is frozen, meaning water has blocked the passage, you will have an overrun of water, which will be frozen. Clean this area thoroughly. After cleaning this area you will see the entry to the condensate line. Pour luke warm water though this passage. Listen for water to start falling into pan.! There you just fixed it.! Good Luck E1. and thanks again GDCROFT!
  • 192 Answers
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
Posted on May 31, 2009
Why did the shelf under lower bin freeze?
Many refrigerators today are having issues with the drain hoses clogging. This lets water collect in the lower drawers/shelves where they either leak onto the floor or freeze. Unclogging the hose is the only fix for this. Manufacturers know about the problem, but are doing nothing about it since they rarely need cleaning before the end of the warranty periods.
Oct 22, 2015 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr
Apr 28, 2009 | Kenmore 64802 Top Freezer Refrigerator
Need shelf
Sears Parts Direct
Part for KENMORE, Model # 25336608896 Shelf, sliding, wiring
Part # 218272502 Category:Refrigerators and Freezers $34.41 In stock
Apr 23, 2009 | LG LRTP1231W Top Freezer Refrigerator
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Whirlpool top freezer leaking into refridgerator.
Sounds like you need to clean the drain again.. if Im understanding right you fixed it once already and lasted 3 weeks.. sound like it plugged up again.. make sure drip pan under evapurator is clean
Sep 24, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
620 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
