Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet runs but will not go forward or reverse
The engine runs but will not go in to forward or reverse.
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Posted on Apr 22, 2010
SOURCE: 96 cub cadet 2140 with cummins onan 14hp
I have cummins cub cadet Onan Elite 140 engine shuts off after about 20 min and won't restart for half hour.
Posted on Jun 06, 2010
  • 760 Answers
SOURCE: cub cadet 1050 fuel problem
Clean, gas tank, fuel filter (replace) fuel shut off valve, and then clean carb, starting with bowl.
Posted on Jul 23, 2010
I have cub cadet that will not move forward or reverse it has a dive shift not a belt
Jack the machine up and with it in gear try turning the drive wheels by hand. DO NOT START ENGINE. If they turn by hand with no force being used then I suspect you have broken the shear pin in the drive wheels or in the drive shaft.
Oct 04, 2016 | Cub Cadet Garden
How do I disable the two safety features on the Cub Cadet xt1, namely the seat cutting out the engine when off and not being able to cut grass in reverse?
Why do you want to disable these features? The mower is designed to cut going forward, it probably does not work well in reverse. And the seat feature is meant to stop it from running you over if you fall out. That being said, you probably either just need to short or disconnect the wires leading to the sensors in the seat. I'm not sure how you'd get it to cut going backwards. I personally wouldn't try either, as it would void your warranty and make it less safe to operate.
Jun 11, 2015 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub cadet 1110 hydro no forward or reverse
Have you check the fluid leval in it at all, It could be right down if you never check it ,End everry thing in it siezed up.
Oct 25, 2012 | Cub Cadet Garden
Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
May 04, 2011 | Garden
Cub cadet starts but won't move forward or reverse ? what should i try to do?
Apr 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Aug 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 PTO problem
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
266 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
