Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
I have a ryobi 825r gas trimmer it will start but it will not turn the attachments. The motor runs fine and when i pull the trigger it revs up but it will not turn the string for the weedeater attachment or the blade for the edger attachment.
  • 37 Answers
There is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
Posted on Jun 01, 2009
My trimmer is a Ryobi 825r and the flex cable is broke.
remove the head from the tube and pull it out
remove the tube from the motor end and pull the rest of the cable out
replace the cable and re assemble
take it to a mower shop for repairs
go to a junk shop and get a straight shaft and have no more problems
Sep 26, 2016 | Ryobi Garden
My ryobi 825r 26.2 runs on idle but when i give gas it dies
you need to adjust the carburetor.hi speed jet.
Jun 27, 2016 | Ryobi Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Ryobi 825r trimmer turns very slowly
The connection between the two shaft has a molded lead piece that the upper half is suppose to match with the attachment. If it not square you will need to replace the lower shaft.
Merry Christmas
Dec 22, 2009 | Ryobi Garden
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Ryobi 825r 4 stroke grass trimmer fires momentarily then stops.
I would say try adjusting the carb screws further out,or start by winding all the way in then out 1,5 turns.
Mar 22, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
615 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
