Question about Dell Latitude D600 Notebook
Have no way to connect wirelessly
Before I reinstalled windows xp on my Dell, I could connect wirelessly through the router near my home computer. I reinstalled Windows XP home edition (the previous version was professional), and now I can't find any way to get to the wireless program it used to have. HELP!
Thanks
  • Mayla Oct 23, 2007
    I checked around and I don't even have the ability to create a wireless connection through network connections, maybe SP2 will help?
  • seunshoy Aug 14, 2008
    i format my laptop D600 and after the format i found out that the dell wireless card utitlity is not comming up like it does before pls i want to know y its so and if there is any thing i need to do to recover it back. And also if possible i can get the network controller i would't mind how much it can cost me to get it. pls send me mail or the download of the network controller to seunshoy@yahoo.co.uk.
    thanks and God be with u. Great WOCOSAIT.
    Scholar:
  • 90 Answers
Sounds like you need some drivers installed, especially if you just installed XP clean.
Visit support.dell.com, click on Drivers and Downloads, click on the service tag option and enter your service tag located on the bottom.
This will take you to a list of drivers for your specific model. Make sure the OS chosen is Windows XP and in the list you should find some wireless drivers. There may be several different wireless drivers listed. And one of those will be specific to your needs.
You might need to identify which wireless card you have first. Which will requrie gaining access to it to get some part numbers or model numbers from it. There should be an access panel on the bottom that you can open to gain access to the mini-pci wireless card. That way you can see which one you have and download the correct software for it.
Posted on Oct 23, 2007
Bt Homehub 3 + dell 1450 wireless router asking for network key
if the routor is wireless then the key is on the bottom or side of router. the ip address should be on it too and pass key to change the settings on the routher
Jul 01, 2017 | Dell 1450 (D1450U) Wireless Adapter
I reinstalled windows XP and now my Linksys wireless router will not connect to the computer. I reset the router. There are three computers on the network. The only one that can/t connect is the one with...
My friend,
In that computer go to the wireless connection in the control panel.
And try to connect through the Windows utility.
Don't forget to start the wireless zero configuration from services.msc
To get in to services.msc in xp
Click on run and type services.msc
Then search for the wireless zero configuration .
Start the service.
Make sure if there is any other utility is there on the computer then disable that.
Dec 17, 2010 | Linksys Wireless-G WRT54G Router
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 22, 2010 | Dell Inspiron 1525 Notebook
Dell Dimension 4700 - Driver Reset
1st you need to download or install all the drivers for your Dell computer. Try to use the drivers/utilities disks first. Once you can get online, go to Dell.com and look up your model 4700 and download all the missing drivers. Your Linksys Router is not a modem. The Linksys has the modem connected to it for wireless connections.
Jul 04, 2009 | Dell Dimension 4700 PC Desktop
I use a home network set up using a Linksys Wireless-G WRT54G router. I just had to reinstall Windows XP home edition on a Dell Inspiron 9300 computer. In hardware manager, the computer lists the Dell and...
Make sure you have fresh ip address...
go to command screen: ipconfig /renew
If this doenst work you can static the IP of the Wireless NIC. Make sure the IP you use is on the subnet of the router.
http://ask-leo.com/how_do_i_configure_my_static_ip_address.html
Jun 22, 2009 | Linksys Wireless-G WRT54G Router
Cannot get internet connection
You probably have to buy a wireless card and and install it in your computer...there wasn't much in the way of home wireless back in 2002.
Go to your device manager and look at the network adapters and see if you have a wireless adapter installed on your system. If not, you will have to put a wireless pci card in and install it and then you will be able to configure your computer to connect to your router with a wireless connection.
Mar 28, 2009 | Microsoft Windows XP Professional With...
Cant connect to my wirelessmodem
Try running the cd that came with the router again, since you reinstalled windows, the configurations for the router have been lost. If this doesn't help let us know and we'll work on it from there.. good luck!
Mar 14, 2009 | Dell Dimension 3100 PC Desktop
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
I have receintly bought a dlink wireless notebook adapter so i could set up my wireless wifi network at home to connect my compaq presario 900 to from a PC. I have installed everything and im getting a...
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks?
I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS.
Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again.
Hope this helps.
Jun 21, 2008 | Computers & Internet
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Dell Latitude D600 Notebook Logo
126 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
