Question about RIM BlackBerry 7290
Dvice error 365 reset
Dvice error 365 on my blackberry 7290 handheld screen
    President:
  • RIM Master
  • 688 Answers
You will need to restore the handheld software on your device.
Download the latest version of Blackberry Desktop software and install it.
make sure you have usb drivers for your device
download the latest version for your handheld,
hook your black berry up and with Blackberry desltop running you will see your pin in the bottom left.
open application loader and reinstall all of the software you need from the core system all the way down.
once it is finished it will try to hook back up. cancel and unhook. remoce battery and replace batery and phone will reboot.
Good Luck
Posted on May 31, 2009
  • 489 Answers
In alot of cases Device Error 365 means the unit is dead., it's not ever gonna work again.
365 is hardware error. Some cases it has been resolved with forced OS reload, but in many cases it's dead
My RIM Blackberry 7290 comes up with "Device Error: 365 Reset". Whatever key I push, it still comes up with the same message.This problem started after taking the battery out to insert a sim card. Tks
you probably either messed up your battery, scratched your sim card, or got something wet. i would ask a phone technician cause you might need some help.
Dec 15, 2009 | RIM BlackBerry 7290
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
7290 device error 365 help me
cause The BlackBerry device is unable to complete the initialization process. Resolution Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
Oct 31, 2009 | RIM BlackBerry 7290
Devce eror 365 reset
Jul 09, 2009 | RIM BlackBerry 7290
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Apr 04, 2009 | RIM BlackBerry 7290
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Error 365 showing blackberry 7290
Hello Sir
To delete all the data, go into Options / Security Options / General Settings, clik the wheel and then click Wipe Handheld.
This will remove all of the DATA, and not any of the applications.
Feb 21, 2009 | RIM BlackBerry 7290
Dicice error 365
pls Send Solution
Sep 09, 2008 | RIM BlackBerry 7290
i am facing same issue error 365
Apr 09, 2008 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
559 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
