Question about McCulloch FHH18A Electric Pressure Washer
McCulloch M#FHH18A High Pressure Jet Washer,
The problem that I have, is that the auto Start/stop feature does not work, when the trigger is relesed the pump still runs and does not shut off. please advise. Thanks, Mark I have a McCulloch FHH18A. The trigger appears to have some type of leak. Water is spraying out of the sides of the trigger. What happened?
Pump will not shut off when the sprayer nozzle trigger is releasd on my McCullogh electric press. washer mdl fhh18a
Likely means you now have a leak in the high pressure area. Could it have been frozen over the winter?
Shutoff is pressure activated...
Jun 20, 2015 | McCulloch Garden
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
Doesn't attain high pressure
possible orifice is clogged,either end of connecttion
Apr 20, 2010 | McCulloch FHH18A Electric Pressure Washer
McCullough pressure washer
I nedd a manual for a FHH18A pressure washer
Apr 07, 2010 | McCulloch FHH18A Electric Pressure Washer
I need a manual for a McCulloch pressure washer FHH18A. Download did not work.
I need a manual for McCulloh 1600 PSI pressure washer > Its motor is working but there is no pressure
Aug 23, 2009 | McCulloch Garden
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
My power washer does not let the soap come out when you turn the soap control on
You have to use the SOAP nozzle (Black Tip)  It is a low pressure nozzle.  The venturi effect prevents the psiphon under high pressure
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch FHH18A Electric Pressure Washer Logo
282 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
